Does AC system charge capacity include the compressor oil?
Old Jun 24, 2015 | 06:34 AM
SW20FL's Avatar
Default Does AC system charge capacity include the compressor oil?
I have 2 quick questions for anyone that works in automotive AC.
1. Do you have to add AC compressor PAG oil every time you evacuate, vacuum and recharge, or only when the compressor is replaced? AKA does all of the oil come out as well when you evacuate the system? Same thing for purge? (unintended purge. Had a high pressure line go out).
2. Do you have to compensate the refrigerant for the compressor oil you add?
For example. If the system takes 22 oz of refrigerant, and 4 oz of compressor oil, do I add 18 oz of refrigerant?
I want to make sure I don't overcharge or undercharge the system.
Thanks guys
Old Jun 24, 2015 | 12:10 PM
tony_2018's Avatar
Fish Twig
Default Re: Does AC system charge capacity include the compressor oil?
The answer to these questions vary because we dont know if you're recharging, had swap out bad parts, or redid the entire system.
Old Jun 24, 2015 | 01:09 PM
SW20FL's Avatar
Replaced compressor, drier, condenser, evap core, seals, and expansion valve. tested for leaks and good. Charged it up with an industrial shop R134a system. Everything worked well for 30 days. Then the high pressure line went out a month after unexpectedly, and I lost all of the refrigerant. Replaced both lines and about to recharge.
I am wondering if I have to re-add the PAG oil. If so, do I have to compensate the amount of R134a?
Old Jun 24, 2015 | 03:40 PM
Former User's Avatar
Did you check the service manual? I'm pretty sure your questions are answered there.
You definitely need to add some oil. Did the replacement compressor have oil in it?
If you want professional help, you'll need to pay for it. On a forum, you get what you get. But it's free.
Old Jun 25, 2015 | 04:47 AM
tony_2018's Avatar
Fish Twig
You are suppose to add oil before testing. I went by the helms manual, it tells you how much goes into each component.
minvikes
Jul 11, 2011 12:06 PM
Kid_SiR
May 7, 2011 09:47 PM
Horizons1
Apr 12, 2010 05:17 PM
JohnnyEF
Jul 28, 2009 08:02 AM
Petah
51
Oct 31, 2003 06:41 PM
