Speedometer and ODO stopped working
Old Jun 24, 2015 | 06:24 AM
hondab1015's Avatar
Default Speedometer and ODO stopped working
Hey guys I have been out of the Honda thing for a while but just picked up an swapped EK hatch to have fun with.
I was driving yesterday and all the sudden the Speedometer and Odometer stopped working. Do you have any idea where to start the trouble shooting?
I see the car has a obd2-obd1 Jumper on an OBD1 computer. The car is a LS Vtec LS trans. I checked the VSS connection at the transmission and it was tight and clean.
Any ideas??
Thanks
Old Jun 24, 2015 | 03:46 PM
Former User's Avatar
Default Re: Speedometer and ODO stopped working
CEL codes?
Old Jun 24, 2015 | 06:04 PM
D16Z6_Trung's Avatar
maybe change the speed sensor?
Last edited by D16Z6_Trung; Jun 24, 2015 at 06:05 PM. Reason: either that or the panel it self need to be look at
Old Jun 26, 2015 | 07:44 AM
hondab1015's Avatar
No CEL but I just read the other thread about possibly being the Speedometer Board in the cluster itself so I am going to check it out.
I did notice at high RPM the tach and speedometer out jump all around but then all the sudden the speedometer just stopped.
Old Jun 27, 2015 | 09:56 AM
jonsey1886's Avatar
10 Year Member
Check the FAQs and find the fuse 15 TSB. Read it and you should be able to fix the issue
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
Old Jun 28, 2015 | 11:58 AM
ej1v's Avatar
speed sensor,also check the cluster...try putting in a different one and see what happens, there's also a possibility a fuse is bad under your dash.please check them
Old Jun 28, 2015 | 10:53 PM
HairyHarry's Avatar
The speedometer was dead in my car not too long ago and it wasn't the speed sensor. I took apart the cluster and it seemed the needle was 'sticky'. Lubed it a little which got the needle to go up a little but wasn't close to accurate. Ended up buying a cluster from ebay and swapping the speedometer. Now it works
Old Jun 29, 2015 | 07:55 AM
Does the CEL work?
Old Jun 29, 2015 | 10:06 AM
moore_716's Avatar
check everything others have stated. My speedo stopped on me but once in a while it would jump at random. I removed the speed sensor and there was a fair amount of slop in the shaft. I bought a replacement online and the problem disappeared.
Old Jun 30, 2015 | 01:45 PM
hondab1015's Avatar
Digging further into it, its intermediate. At high RPM's it jumps around a lot but driving normal it seems to be pretty solid.
Im going with either the VSS is truly going out, or the board in the cluster. I put it all back together and drove 200 miles and it hasn't gone back off just jumps around at WOT and 6+k RPM.
xlusiveracer
21
Apr 12, 2017 07:20 PM
ONEhaque
Nov 4, 2008 06:31 PM
andyb52182
Aug 31, 2008 09:40 PM
cktenders
14
Aug 28, 2007 08:12 PM
rerun07
Dec 8, 2005 08:21 AM
