integra not idling help
Old Jun 23, 2015 | 07:25 PM
potatointegra01's Avatar
Default integra not idling help
i got new valves intsalled and after that my car wasnt idling until i hold the gas.
can this be because i need a valve adjustment? i also have a engine code thats p0331 for the intake sensor, i never had the sensor and i never got the light come on before, can this problem be making my engine not idle?
any thing i should check to see why it could be running like this? all the sensors are in the right place they came out of.
the only way i can make my car idle is if i remove the hose coming from the firewall to the back of the intake but as soon as i cover it with my thumb or connect the hose its will die out slowly.
any help or advice would be much appricated.
Old Jun 24, 2015 | 12:52 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: integra not idling help
If you had the valves replaced then yes you will deff need to check and set the valve lash!
I believe the code p0331 is for the knock sensor! yopu might have a bad knock sensor.
make sure the iACV is plugged in and not switched with another plug, i think theres another plug in that area that can reach and plugs in.
Kayronn Grier
Dec 3, 2015 06:24 AM
lowered94accord
May 7, 2007 09:24 PM
stivic
Oct 14, 2004 05:58 PM
stephenB!
Mar 12, 2004 06:33 AM
AprilzWarrior
Nov 4, 2002 05:19 PM
