problem with performance
Old Oct 13, 2004 | 07:18 PM
stivic's Avatar
Default problem with performance
I just did a gsr swap in my civic and its been running for a few weeks now, I got am having a little power loss though i got the knock sensor hooked up Im not sure about the IAB (intake air bypass) sensor if thats hooked up or not but my IAT (intake air temperature) sensor was either broken or i dont know the plug wouldnt stay on the sensor itself so i caucked it a little so it would stay I was getting a TPS (throttle position sensor) code on my check engine so i replaced that whole sensor and all the codes went away but when i drop it down all the motor seems to do is backfire like some sort of studder in the throttle, it goes but it doesnt have any power really, Im thinking its one of those sensors being IAB not hooked up or IAT would anyone have any ideas
Also, theres a some sort of scraping sound coming from my engine when it deRevs like when the RPMs go down its like a metal scraping sound and thats coming from under my valve cover somewhere, i just got a valve adjustment and that took care of some ticking but it still makes the scrape sound i dont know what that could be either
IF anyone has an idea of what my problems could be I appreciate it, thanks
Old Oct 13, 2004 | 07:42 PM
lke2drvgsr's Avatar
Default Re: problem with performance (stivic)
damn that post was a bitch to read.. use punctuation next time.
have you tried a compression test to make sure you're not losing compression? i don't know what could be causing that metal grinding sound in the motor... anyone have any ideas on that one?
Old Oct 13, 2004 | 07:44 PM
stivic's Avatar
Default Re: problem with performance (lke2drvgsr)
yeah im about to get a compression test done, My idle is high though would not enough compression make my idle above 1k, Someone told me that it could be coming from the clutch or flywheel but why would those make scraping sounds when I rev
Old Oct 13, 2004 | 07:47 PM
lke2drvgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah im about to get a compression test done, My idle is high though would not enough compression make my idle above 1k, Someone told me that it could be coming from the clutch or flywheel but why would those make scraping sounds when I rev </TD></TR></TABLE>
well, the flywheel could possibly be making the scraping sounds since it revs with the motor but idk what it could be scraping against.. do you have any smoke coming out ur exhaust either when it's idle or when you're on it?
Old Oct 14, 2004 | 05:14 AM
stivic's Avatar
yea smoke comes out when im idle and when i throw it down more smoke comes out sometimes
Old Oct 14, 2004 | 05:58 PM
lke2drvgsr's Avatar
what color smoke? white? blue? black?
Marcos Garcia
K Series
Oct 17, 2017 02:55 PM
hatch96y7
31
Mar 25, 2008 07:30 PM
K i l l a B e e.
Jan 2, 2008 01:32 PM
99spanishGT
Mar 11, 2004 07:07 AM
