what turbo to use for my setup?
im trying to figure out what turbo would be best for my setup? either garrett super 60 /5558? or a turbonetics .63 AR?
my setup
lsvtec
block darton sleeved
82mm wiseo 9:5:1 comp ratio
manley h beam rods
girdle
ls crank
head
gsr
supertech valvetrain(the whole 9 yards)
gsr cams
bwr cam gears
3angle valve job
port amd polished head
port and polish victor x im
bbk 70mm tb
1200cc injectors
aem fuel rail/fpr
255lph fuel pump
fuel cell
an fuel lines
bwr top mount manifold
46mm wastegate 21psi(will run 28psi sometimes too)
precison 600hp fmic/piping
theres more just thats the main stuff.
so what turbo would be best? my limit to pay is 800$ maybe 850$
im looking for 450-550hp
if theres any other turbos that you could recommend lmk. the motor is all together the turbo is the last piece i need
my setup
lsvtec
manley h beam rods
girdle
ls crank
head
gsr
gsr cams
bwr cam gears
3angle valve job
bbk 70mm tb
1200cc injectors
aem fuel rail/fpr
255lph fuel pump
fuel cell
an fuel lines
A Garrett GT30R would be great for what you want, but is a good bit outside of your price range. An STC Silver Surfer would probably do nicely for what you want, and is listed for $899 on their website, if you're willing to up your budget just a hair. Remember, you get what you pay for.
It's a hair on the big side for your goals, but not horribly big. It's price tag is way too big for your current budget, though. I'd bet the Silver Surfer would probably be a better match for you, though (and a little cheaper, too).
i think im going to go with the silver surfer thanks man
keslerbuilt
Jun 21, 2015 07:19 PM
