is a borg warner s366 turbo to big for my build
im building a lsvtec an was bought a brand new borg warner s366 for 400$ off a friend who decided to go bigger and was wondering if its gonna be to big or if it will get my goal
my setup
92 ls block
darton sleeved
82mm wiseco 9:5:1 pistons
manley h beam rods
ls crank
block gaurd
95 gsr head
gsr cams
supertech valvetrain
bwr cam gears
victor x im
bbk 70mm tb
1200cc injectors
aem fuel rail
255lph fuel pump
an fuel lines
bwr top mount manifold
46mm wastegate
precison 600hp fmic/piping
im gonna be running 25psi
and was shooting for 400-500
ill be happy with 400
just wondering if that turbo will get to my goal or if its going to be to big i have everything built and ready to go just wondering if thats going to be a good enough turbo i was going to get a 6266 but i came across this one
my setup
92 ls block
darton sleeved
manley h beam rods
ls crank
block gaurd
95 gsr head
gsr cams
bwr cam gears
victor x im
bbk 70mm tb
1200cc injectors
aem fuel rail
255lph fuel pump
an fuel lines
46mm wastegate
Re: is a borg warner s366 turbo to big for my build
That turbo is too big for anything less than 600. You need a much much smaller unit. A 57/60 trim t3/4 or gt30 is the right size. Pte 5431/5555/5558 works too. I think a 6262/66 is too big as well. Idk why everyone talks abt big turbos like they're necessary to make big power. I saw a guy selling his em1 using a 6262 on a b16 to make 370whp. Literally. Wft is the point of boost onset at 6500 rpm. You have a 82x89 with 9.5 cr. You need the smallest turbo to get you to 500 HP. Not one capable of 500-900 HP.
also would this work? TURBONETICS 11008 T3 T04 60 AR.63 60 Trim
its hp rating is 350-450.
im probably gonna get the precison pt5558
its a street car but im running slicks on the street all of our cars we run slicks on the street with vht sprayers infront of the tires, when we start racing we hold the button to spray the vht the whole time.
