Condenser fan re wire.
Old Jun 22, 2015 | 08:47 AM
onunezp's Avatar
Default Condenser fan re wire.
Hi fellas, i have a question, can i connect my condenser fan to my radiator fan? i dont know why it doesnt come on with the AC, howeve if apply electricity from the battery, it runs, is my rad fan relay capable to hold both fans? can i connect both relays to a same power circuit by connecting the condenser fan just before the rad relay? im only wanting to do this while im able to take the car to a shop and have it repaired. thank you
Old Jun 22, 2015 | 11:23 AM
Tachi's Avatar
Default Re: Condenser fan re wire.
When you turn your AC on, does the compressor start spinning as well? Because if there isn't enough refrigerant pressure in the system to engage the compressor clutch then its not going to turn the fans on either.
Old Jun 23, 2015 | 07:30 AM
onunezp's Avatar
thank you, yes, the compressor works perfectly, i can use my ac when the car is going fast, its cold, but when it stops or i decrease speed, its hot air coming from the vents.
Old Jun 23, 2015 | 07:53 AM
scubacamper's Avatar
Have you checked relays/fuses?
Old Jun 23, 2015 | 01:56 PM
Tachi's Avatar
Would be my next suggestion. Check the fuse/s in the AC system and and test the relay/s.
Old Jun 23, 2015 | 07:42 PM
onunezp's Avatar
thank you guys, im gonna do that tomorrow and get back to you to tell you how it went
Old Jun 24, 2015 | 03:38 PM
onunezp's Avatar
ok, so i checked the fuses, 4 and 8 under kick panel, 34 under hood, checked the relay by closing the circuit directly with the battery and it clicks, right now i dont have a voltmeter, what should i do next?
i must also add, since the first post, (i forgot) my radiator fan comes on AS SOON as i put the key in the ON position, even in the morning. whats up with that.
Old Jun 24, 2015 | 05:05 PM
rockycat's Avatar
If your ac is on that is normal but the condenser fan should run also.
Old Jun 24, 2015 | 08:58 PM
Tachi's Avatar
Multimeters are cheap, I'm not sure where you are but the ones at Harbor Freight aren't garbage and everything is made in China anyway unless you're buying a Fluke. That said, if your rad fan comes on right away, I'd suspect the coolant temp sensor, or the temperature switch for the fan, if it exists, is stuck closed.
Old Jun 24, 2015 | 09:07 PM
onunezp's Avatar
thank you, im in Central America, and yeah, im going to buy one tomorrow or the day after tomorrow,
can the coolant temp sensor, or the temperature switch for the fan, affect the functioning of my condenser fan?
Old Jun 25, 2015 | 04:13 AM
rockycat's Avatar
Unlikely given what you post.
Old Jun 26, 2015 | 07:37 AM
...makes me think 1 of 2 things:
- we've got the terms wrong for the fans
- you've got them wired backwards.
Standing at the front of the car, peering down into the motor bay: The left side is the cooling fan, the right side is the condenser fan.
The left side should turn on at normal operating temperature, and can even come on when the motor is off, to help cool the motor.
The right side should turn on when you turn your A/C on.
Old Jun 26, 2015 | 03:17 PM
onunezp's Avatar
thank you, i got exactly as you stated, the left one (cooling) comes on when i put the key in the ON position, even if the engine is morning cold, the condenser fan (on the right) does not come on when the AC is on, the compressor kicks in though.
Old Jun 26, 2015 | 03:46 PM
rockycat's Avatar
Is the ac on in the morning when engine is cold??
Old Jun 26, 2015 | 08:10 PM
onunezp's Avatar
Nop, ac is off, condeser fan off, cooling fan on
Old Jun 27, 2015 | 12:29 PM
onunezp's Avatar
ok, so i did something, i swap relays, put the cooling fan relay in the place of the ac fan relay and viceversa, this is what happened, when i turned my car on, both fans were working now, but when i push the ac button, compressor didnt kicked in and the fan stoped. what can i do next, are both relays ok or what?
Old Jul 1, 2015 | 07:11 PM
onunezp's Avatar
Can i use this one? i bought it, but im not sure if i can use it in the car, it says domestic use in the box
Old Jul 2, 2015 | 01:41 PM
onunezp's Avatar
Ok, so last post and update,
my condenser fan is now working, it was full of dirt in the inside, so i used a little sand paper and all done, took me like 40 mins to left it super clean and nice, i reinstalled it and it worked, i used this video
<iframe width="560" height="315" src="https://www.youtube.com/embed/uerxvIBODOE" frameborder="0" allowfullscreen></iframe>
angrysmileyface
May 12, 2018 11:24 AM
orangeracer
Jun 28, 2008 09:01 AM
92spoonlude
Mar 31, 2007 03:29 PM
jazz215
17
Jul 27, 2003 05:17 PM
