98 civic dx code p0135
Ok my father has a 1998 civic dx with 195k on it. the car runs like a champ. it's kicking a code for upstream 02 sensor. When getting ready to change the sensor I noticed the manifold had a crack. So long story short we changed the manifold and cat. It's all one unit, both up stream and down stream 02 sensors.
The reason for changing everything was he put around 85k to 95k in the last few years on the car and it's already apart what's another 50 bux for a sensor. Well after replacing everything very carefully we are still getting a code for up stream 02. So we swapped in 2 other brand new sensors. 1st a Bosch, the next one recommend by a buddy a Denso part number 234-4099. Still kicking the code as soon as you fire the car up.
I have no idea what to try now. I need to fix this because the car needs to pass a nys inspection..... Any help or links to the solution would be great.
Did what you said everything checked out, and was working.
The ecu turned out to be bad. Got one off eBay and got a inspection.
b18c-gsr
Jan 30, 2025 04:40 AM
oversteer_ms
Nov 5, 2012 10:08 AM
mikeycivic
Sep 21, 2011 03:57 AM
