Check engine problem
So I have a Honda Accord 2003 4 cylinder VTEC and I have the check engine light on. It reads 2 codes the first says rocker arm actuator stuck on bank 1 and the other is a knock sensor malfunction. the problem started in winter when I would drive, anytime I got above 2.5 rpms the engine would get loud and slow way down but not stall out. I talked to someone at autozone and he said it was probably that my timing valve had gone bad and that it would be a costly fix. But when I took it to a shop when they looked it up they suggested an oil change which hasn't really done anything besides the car doesn't slow down anymore when I start driving, but I still notice some hesitation when I go to accelerate. Other post have said to change the oil pressure switch and the knock sensor but I wasn't sure what I should really do because mine seems a little different from others seeing how my car keeps hesitating before accelerating faster.
CrisEK
13
Jun 12, 2005 02:48 AM
