engine knock sensor??
Old Jan 21, 2009 | 08:33 AM
JDM SIR-G's Avatar
Icon2 engine knock sensor??
i just changed my oil yesterday in my gsr motor, but the thing i did different is put about a half of quart of lucas oil stabilizer, i was driving my car later in the day and when i hit the vtec sometimes it would throw on my check engine light and my car will just barley idle and wants to die. i would hit the vtec again and it would not even pop, it feels like the car is running very rich. since i run 5w30 could this be too rich with the oil stabilizer? and when my check engine light goes on in this case could it be because of my knock sensor?
thanks
Old Jan 21, 2009 | 08:49 AM
mouab18c1's Avatar
Default Re: engine knock sensor??
did you diagnose your CEL? if you did what was your CEL code?
Old Jan 21, 2009 | 09:33 AM
JDM SIR-G's Avatar
no im not to familiar with diagnostics.
Old Jan 21, 2009 | 10:28 AM
mouab18c1's Avatar
then how do you know its the knock sensor? did it ever do this before? try switching back to your regular oil
Old Jan 21, 2009 | 11:22 AM
JDM SIR-G's Avatar
i dont know if its the knock sensor, but yea i am going to put just my original oil in. thanks for the input.
Old Jan 21, 2009 | 01:36 PM
hondakevin21's Avatar
Did this problem ever occur before hand or just now that you changed the oil?
Can you take it down to autozone and have the CEL checked out?
Old Jan 21, 2009 | 02:45 PM
mmuller's Avatar
Mad Scientist
check codes and report back...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
how to there
Old Jan 22, 2009 | 01:21 PM
JDM SIR-G's Avatar
yea im going to do that today and ill report back. thanks
Old Jan 22, 2009 | 06:06 PM
HONDAGENIUS's Avatar
Try putting vinegar in gas tank to clean out the RFG-18 injector...or you could check your codes and report back
Braden Bullard
Mar 12, 2019 02:53 PM
ddbraungart
Honda CR-V & Element
Feb 24, 2018 08:34 AM
lango-H22
Dec 2, 2012 06:15 AM
brettnahmann
Aug 2, 2012 09:55 PM
integramic
Sep 15, 2004 05:52 AM
