Factory ECU REFLASH
Any Aftermarket performance shop that deals with Hondata in your area.
You may need to go to Hondata's Dealer List and make some phone calls. But you would need to purchase Hondata equipment from them in order to do this. The Honda ECUs are not like those from other manufacturers that are able to be adjusted by way of Open Source or some programmable hand module.
Not to "flash" anything, no.. I'm skipping the notion of that being a possibility by ignoring it completely, and going with an aftermarket alternative, which is a Hondata solution.
If the ECU that the OP intends to use is a DBW type and Hondata offers a FlashPro for this ECU application, couldn't a Hondata dealer with a Dealer FlashPro system program an alternate basemap in the ECU in question... or even create a custom tune specifically for the OP's engine combination ???
SJdc5
Feb 17, 2006 11:46 AM
