Valve Cover Install
Old Jun 3, 2015 | 05:43 AM
Zach Clinger's Avatar
Icon2 Valve Cover Install
Hello All,
I just ordered a new valve cover for my 01 GSR (for asthetic purposes) and when it came in, it came with a piece of paper saying I *should* clean the underside before mounting it on my car as it may damage my car.
Can anybody shed some insight as to how I should go about cleaning this properly?
Thanks.
Old Jun 3, 2015 | 02:26 PM
GagnarTheUnruly's Avatar
Default Re: Valve Cover Install
I would think any solvent that dries clean would be ok. Carb cleaner and a paper towel could work.
Old Jun 9, 2015 | 05:02 PM
kramerdachamp's Avatar
Use purple power. It works very well. I find solvents can hurt the paint if your not careful where you are spraying.
Old Jun 9, 2015 | 11:49 PM
Bently_Coop's Avatar
Steve at Heart
Brakekleen non chlorinated can like pictured below is less corrosive. Also you are basically removing any machining oils from the factory production. If you have alcohol prep pads they work well for the gasket channel as well.
BEYAAAH
Jun 4, 2007 11:17 AM
vtec.dc2
May 8, 2006 07:17 PM
95greenteg
Aug 30, 2004 09:44 AM
Rwecked
Jul 14, 2002 10:00 PM
DCtwoR
Jun 13, 2002 12:07 PM
