main relay buzz
Hi guys first time poster, ive looked near everywhere to figure out why my integra doesnt want to start. The main relay buzzes when im about to crank, i hear the fuel pump send gas to the engine so fuel pump relay is good. I read that if the main relay buzzes three time its good but i just hear it continuously. I bought the car in march and hasnt given me problems since. Its a 96 rs integra with a obd1 conversion. Any help is appreciated
Mine did the same thing but it was on my ef hatch
I would turn the key hear the fuel pump work and everything
But the main relay would buzz and it was a long buzz
Turned out to be a bad ground
so I would check that out just in case
Thanks i did that too and i did a little tune up with ngk irridium spark plugs and that did the trick. Now the little rascal wont go above 2500 rpm. I've read that it could be tps sensor, ecu, or distributor. Im going to be replacing the tps soon but i dont want to waste money on something that doesn't need replacing. If anyone can point me in the right direction. Thanks
here's the tps test, if it needs replacing grab a dorman. bought blox and it was junk. f u blox! 8(
https://honda-tech.com/honda-crx-ef-...hread-2830131/
