Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Electrical Failure Help!!
Old May 25, 2015 | 09:42 AM
mech99's Avatar
Default Electrical Failure Help!!
Yesterday a loose cat lower heat shield was ripped from my 04 Odyssey while driving taking the downstream o2 sensor wiring with it. Immediately the Check Engine, Supplemental Restraint System, Traction Control and door ajar lights all went on. The drive indicator began to blink and the transmission mostly disengaged. It would still drive but it was as if it was slipping severely. The next day I replaced the o2 sensor but the symptoms remained. After a short test drive I discovered that the gauges and odometer were intermittent. After a stop and attempt to restart I discovered the alternator had stopped charging. Volt meter shows about 10v at the battery terminals while running after a jump with voltage steadily falling. Checked the wiring downstream of the o2 sensor connector and it looks unharmed. All fuses ok. Attempted to reset the ECU according to some online instructions (which I'm suspicious of). Any help or insight would be much appreciated. Pretty Desperate in KY
Old May 25, 2015 | 12:06 PM
lazlong's Avatar
Default Re: Electrical Failure Help!!
Sounds like it knocked a ground loose too. Check all wiring that is anywhere near the underside again, especially up around the alt and that area. Can you read any codes?
Old May 25, 2015 | 01:51 PM
mech99's Avatar
Thanks, took a look under and could find nothing but will continue looking. Will put a code reader on tomorrow.
JLCustomizing
Honda Civic (2001 - 2005)
Jan 21, 2016 05:07 AM
yeedub
Apr 13, 2013 10:35 PM
Libertariat
Aug 20, 2008 10:54 AM
the_illest_soldier
Sep 10, 2005 03:12 PM
EVOCELICA
Nov 20, 2002 11:44 AM
