trying to get my horn to work found out the fuse in the bay was a 7.5 switched to a 20 but realized that my + and ground have continuity at the horn connection and at the relay connection! ?!?! Bought the car like this. Any insight?
Should i just remove the wiring and see Where the leak is?
Could someone run out and check continuity on their working horn: the horn prongs... Just to see if my horn is bad or if it's actually suppose to have continuity thanks
Found out why horn wasn't working.. Positive from the srs wasn't connected last owner had hacked wiring. got the srs cables. I only had cruise control so I jumped the connection from inside the steering wheel cruise control connector. Had to do a little adventuring with the ohm meter and figured it out
|-||| connected the lonely pin to the one that follows
