no compression in all 4 cylinders
Old May 16, 2015 | 10:14 AM
smeroney's Avatar
Default no compression in all 4 cylinders
I have a 05 accord time chain in tact cams are rotating new battery plugs air filter and oil car won't start did compression test in all cylinders no compression at all help
Old May 16, 2015 | 07:02 PM
Muckman's Avatar
Moderator in Chief
Default Re: no compression in all 4 cylinders
Timing chain is off or valves are bent. Confirm cams and crank line up at TDC.
Old May 17, 2015 | 06:42 AM
1990IntegraLS's Avatar
Who adjusted the valves? If you turn the crank (with a socket wrench), you should feel compression or lack their of, by hand. Are you sure the compression tester is any good? Some times they have bad fittings that can leak. With the spark plug out you should be able to hear the compression.
tackhammer629
Jan 18, 2012 04:44 PM
vinuneuro
17
Oct 20, 2008 06:17 AM
VTC_CiViC
Jun 28, 2002 08:05 AM
b18c5T
Jan 29, 2002 09:08 AM
HX_Guy
Aug 22, 2001 02:00 PM
