Compression #'s and Compression Raito.. 1 in the same?
Old Jun 27, 2002 | 12:31 PM
VTC_CiViC's Avatar
Default Compression #'s and Compression Raito.. 1 in the same?
Ok, I know what the CR is (volume of chamber at BDC vs. TDC) and what compression is (amount of air in psi compressed in the chamber). Now to me it would make sense that as the ratio goes up, the actual compression # would go up too (same amount of air, less area to fit it = higher compression #'s), am I right or way off??
Old Jun 27, 2002 | 12:54 PM
Speed PHreak's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (VTC_CiViC)
Correct!
Old Jun 27, 2002 | 12:55 PM
GSRwBOOST's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (Speed PHreak)
what he said..
Old Jun 27, 2002 | 01:06 PM
X2BOARD's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (GSRwBOOST)
So by that fact, would it be correct to assume a motor with a 9.0:1 CR would yield notably lower compression numbers than one that has a 10.0:1 CR ?
Eg: 9.0:1= 180's and 10.0:1= 210's <--- comp numbers used as an example
X2
Old Jun 27, 2002 | 04:45 PM
earl's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (X2BOARD)
Not so. Lot of other factors involved..duration of cams, overlap of cams, cam timing, condition of valves and springs, ring seal, leaking head gasket, amount of carbon on pistons and valves, etc.
It even makes a difference if you do the test with the throttle body open or closed.
Old Jun 27, 2002 | 04:49 PM
Sonny's Avatar
All things being equal, compression #'s and compression ratio will rise together. As Earl pointed out though, things are not always equal. I've seen as much as 20 psi variance on the same engine using different gauges. Additionally, using cam gears to dial in/dial out overlap can change compression numbers, too.
Sonny
Old Jun 28, 2002 | 04:44 AM
X2BOARD's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (Sonny)
Understandable that there are multiple factors involved in reading a motor's compression, but as a general rule, engines with higher CRs will typically have higher compression readings than engines with lower CRs, yes ?
X2
Old Jun 28, 2002 | 05:55 AM
earl's Avatar
No, not even as a general rule because of camshafts. But, everything being equal in the same motor, the 11-1 cr should give a higher compression # than the 10-1.
Old Jun 28, 2002 | 06:41 AM
VTC_CiViC's Avatar
Default Re: Compression #'s and Compression Raito.. 1 in the same? (earl)
Right.. in other words, all other things equal, a motor with a higher CR will yield a higher compression number
Thanks guys.. X2, I'll take delivery of those Z3 fenders tomorrow thanks
Old Jun 28, 2002 | 08:05 AM
X2BOARD's Avatar
Sorry VTC, they Z3's are currently on national backorder. I can, howver, deliver the indiglo 'racing' pedals that you ordered..... I will package them in the UPS box with your MaDSKilLs cucullios....
We take Visa, MasterCard and RicersClub with picture ID only.
ef_si
Jul 25, 2013 02:09 PM
Commiecircusbear
Feb 27, 2008 07:40 PM
.nate
May 6, 2005 06:26 AM
ITR.00-1282
Mar 30, 2003 09:04 AM
evo
Jun 12, 2002 03:45 PM
