dxf files
Old May 10, 2015 | 08:22 PM
efHondefender's Avatar
Default dxf files
Anybody have a .dxf of a T3 flange and a B series head flange for the exhaust manifold.
I looked around on google, but all I could find was jpeg images of drawings.
Old May 11, 2015 | 06:34 AM
that-guy's Avatar
Default Re: dxf files
it cost money for people to make those, believe me, I'm in the industry of making parts, so you're best off to get an exhaust gasket and a T3 gasket, and create your own drawing based on the dimensions
Old May 11, 2015 | 10:17 AM
With how common these flanges are I can't believe they're being kept secret. It's pretty easy to find a dxf file of a small block Chevy header flange. It's not like making the drawing is the difficult part anyway. It's the whole owning a cnc laser or water cutter part. I can find a million drawings of t3 flanges online. They're just jpeg images though. I was just trying to skip a step.
Old May 11, 2015 | 10:24 AM
2fast4u831's Avatar
I'm really 2slow
post a jpeg drawing on here. I'll see if it can be done in my solid modeling class this week.
Old May 14, 2015 | 05:49 AM
ShinsenTuner's Avatar
No Jodas
PM me rough dimensions with a sizes of the holes and a general shape (a hand drawing will do) and I can get it to you.
Old May 21, 2015 | 07:39 AM
.one lane's Avatar
.likes trains
I made a quick dxf on the t3 flange.
https://www.dropbox.com/s/zdlmjav63g...LANGE.DXF?dl=0
Old May 23, 2015 | 07:12 PM
Hites's Avatar
Tell me exactly what year, make, model, & trim vehicle your B-series (and thus exhaust manifold) you're interested in, and I may be able to get you a DXF on Tuesday, 5/26.
If you need help finding a shop that can cut one out for you, just ask, and I'll help locate one local to you (I'm always looking for more reputable machine/fab shops).
PM me all info for quicker response.
Old May 24, 2015 | 09:10 AM
Just need a b-series exhaust manifold flange drawing. They're all the same. My buddy is a high school teacher and they have a plasma table at the school. I can cut them out, I just need the files.
Old May 24, 2015 | 08:42 PM
njn63's Avatar
Fyi, flange dimensions for turbochargers can be found on the Garrett website by looking up a similar turbocharger: http://www.turbobygarrett.com/turbob...71R_flange.pdf
Making a .dxf file from those dimensions would take all of 3 minutes. I just don't have any cad software on my laptop.
Old Jun 1, 2015 | 07:29 PM
RA429's Avatar
I need to make a custom exhaust mani gasket for a gsr soon. I will have a dxf for an oem gasket after I buy one and find time to do it. I will update this thread when the time comes.
Old Jun 3, 2015 | 08:45 PM
I think they should rename this thread ".dxf file share" and make it a sticky. Could prove to be super useful.
Old Jun 8, 2015 | 05:45 AM
Hites's Avatar
I very much support this direction and would support this activity as well.
Get the sticky ball rolling, and I'll help out as much as I can.
Old Oct 22, 2015 | 05:43 PM
RA429's Avatar
Ok guys, I finally decided it was time to get this project moving. I bought a new header gasket and got a DXF drawn up. Keep in mind, it is simply the gasket, not the flange as OP was asking for. It is applicable for all 94-01 B series VTEC engines. This is an unverified first draft so I'm not sure that it matches up exactly, but it should be really close. I will double check it soon and let everyone know of any updates. This forum would be awesome with an open-source Honda DXF file share! Also, the ability to attach DXF files to a post would help tremendously. I don't have dropbox, so if anyone knows a way to publicly share DXF files please let me know. I uploaded the file to sharecad.org It's a free viewer and I think you need to create an account in order to download files.
Here is the file link:
https://sharecad.org/Viewer/Shared?f...DfndgOS34SQ%3d
Old Nov 5, 2015 | 12:29 PM
RA429's Avatar
I now have a Dropbox account which has really simplified everything. I still need to tweak the header gasket file a little bit to perfectly match up the holes. In the meantime, here are a few DXF files I have created for past projects.
-Generic Battery Box for Odessey Battery, mounts to side of hatch
https://www.dropbox.com/s/lhrjufmjjk...Mount.dxf?dl=0
-Behind-the-rotor Spacers, 5x114.3
https://www.dropbox.com/s/ua9uvehbvh...pacer.dxf?dl=0
-Behind-the-rotor Spacers, 5x114.3 70mm ITR Hub
https://www.dropbox.com/s/534qdf0qw7...070mm.dxf?dl=0
-Sheet Metal Spark Plug Cover, GSR Valve Cover
https://www.dropbox.com/s/yxmzu3ogwc...203.0.dxf?dl=0
Old Nov 8, 2015 | 01:10 PM
1sick4g63's Avatar
you forgot the bolt holes on the spark plug cover
Old Nov 11, 2015 | 04:59 PM
RA429's Avatar
Man, I've had a lot of problems with PlasmaCAM not properly exporting holes. Every so often it randomly does the lead in, but not the hole. Easily fixed by changing the G02 to a G03 or vice versa. I'll fix it and update, thanks.
**Holes have been fixed
97Alex
Welding / Fabrication
17
Nov 29, 2011 01:13 PM
Everyones Hero
Sep 24, 2008 09:01 AM
AWDstylez
Jun 30, 2007 08:38 PM
office888
Nov 19, 2006 09:49 AM
timg
Apr 18, 2006 08:00 PM
