Cv axle/transmission play?
Old May 10, 2015 | 06:06 AM
OldSchoolFool's Avatar
Default Cv axle/transmission play? With video
Not sure of the proper terms to use but basically if you grasp the large end of the cv axle that goes inside the transmission on the passenger side it has some up and down movement that seems a little excessive to me but the driver side doesn't have much at all. It doesn't leak any fluid or pop out of gear. I am going to be replacing the passenger side axle soon because the outer boot it ripped and making a huge mess. Could the axle just be worn to cause this or do I have a more serious issue going on?
Old May 10, 2015 | 07:37 AM
holmesnmanny's Avatar
Default Re: Cv axle/transmission play?
If its just the shaft that has play thats normal. If it has play where it enters the differential then thats a different story.
Old May 10, 2015 | 09:13 AM
What do you mean by just the shaft has play? It is where it enteres the trans at. I haven't pulled the axle out yet.
Old May 10, 2015 | 04:10 PM
Not my video but it looks about like this
Old May 10, 2015 | 04:31 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Cv axle/transmission play? With video
If its bad it will leak or vibrate/hum/make noise. If none of the above is occurring,dont worry about it...
Old May 10, 2015 | 06:02 PM
Yeah I don't really notice any of those things. I'm replacing my input shaft bearing this week and just didn't know if it was something I would also need to replace while I had it taken apart.
Old May 10, 2015 | 08:27 PM
I gotta be honest I don't think i've ever seen play like that. Since you're going to be replacing the axle anyhow, obviously you'll see if the new one has the same play.
When you have the case open, check if the differential has any play at the bearings. You can grab the differential and try to wiggle it. It should be fairly tight.
Old May 11, 2015 | 02:55 PM
Okay thanks I'll check that
Old Jul 25, 2022 | 11:13 PM
VtecGang's Avatar
Did you ever fix it ? I am having same issue in my integra passenger side. I put new axles but one has play like that. Was maybe thinking mine was defective from store
Old Feb 15, 2023 | 11:22 AM
Flocker's Avatar
Yes this is what my 05 civic lx is doing right now. I hear a snap sound when I hit the brakes coming from the RF, and also over bumps and pulling out! Snap snap sound since I bought it, and could find nothing loose as in the ball joint or bushings etc! 229k worn out carrier bearings I just found this movement today sadly.It's gotten much worse over time.
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
TEGMAN89
Jan 11, 2011 05:12 AM
WRTEG
Jul 20, 2006 01:43 PM
92sleepR
Mar 21, 2003 12:40 PM
Pearce
Oct 16, 2002 10:44 AM
