Honda S2000 Honda S2000
Bad vibrations
Old May 9, 2015 | 10:23 PM
bigmacnfries's Avatar
Default Bad vibrations
Hey.
I've read a few of the vibration related threads on here, but i wanted to get your opinions.
My car has just started vibrating quite badly. It mainly happens as i apply more throttle, and especially at higher speeds. It's quite a pronounced vibration, and i can feel it through the steering wheel, as well as throughout the car. When i'm only at 5% throttle, or coasting, the vibration seems to go away. The harder i push the throttle pedal, the stronger the vibration.
Yesterday, i didn't notice any vibration, but today it's extremely noticeable.
It doesn't seem to be related to revs at all, just amount of throttle.
I'm thinking it could be CV, or axle, but would it happen that quickly?
All help much appreciated..
Cheers
Old May 11, 2015 | 01:05 PM
JdmTypeRdc2's Avatar
Default Re: Bad vibrations
The number 1 culprit of these types of vibrations seem to be the CV buckets. Are you lowered? If so, there's a pretty good chance you might need to swap them from one side to the other.
Old May 11, 2015 | 03:11 PM
Arsenal's Avatar
Just put in axle spacers.
Search google:
Axle spacers s2ki.com
Old May 11, 2015 | 05:35 PM
Thanks fellas
I've been lowered for about 5 years, but this just started in the last few days.
I did consider axle spacers, so will look at that.
Is the best fix axle spacers,and swap the CV joint/bucket around? And is it safe to drive (low speed, low km's) until it's fixed?
Old May 12, 2015 | 12:30 PM
Arsenal's Avatar
Either or. I just put spacers in and all is good.
Old May 12, 2015 | 10:25 PM
Spacers: not free
Bucket swap: free
Take your pick, they both will fix your issue.
Old May 13, 2015 | 08:49 AM
Arsenal's Avatar
Originally Posted by JdmTypeRdc2
Spacers: not free
Bucket swap: free
Spacers: Quick and easy (two piece)
Bucket swap: Longer to change, messy, PITA
Old Jun 23, 2015 | 12:07 AM
Thanks fellas - axle spacers seem to have completely fixed the issue. The S is now in storage for 6 months while i travel. An air-conditioned secure garage no less
Old Aug 9, 2015 | 08:32 PM
Mleeg42's Avatar
Check engine mounts
kraquepype
30
May 10, 2018 08:48 PM
blackdelslo
Jan 23, 2005 07:27 PM
H22Prelude
Apr 21, 2003 08:18 PM
IntegD
Oct 30, 2002 07:28 AM
BlackAckeR
Oct 29, 2001 12:08 PM
