Is it the Axle?
Old Mar 25, 2003 | 04:44 PM
H22Prelude's Avatar
Default Is it the Axle?
It makes a somewhat grinding, wobble noise when accelerating and when turning right. The weird thing is that it usually only does it when the car is warm. It won't do it when the car is cold, even when I get on it. What else could it be?
4bidden's Avatar
Default Re: Is it the Axle? (H22Prelude)
Yea, either that or a wheel bearing.
Old Mar 25, 2003 | 04:57 PM
BoostedH23a1's Avatar
Default Re: Is it the Axle? (4bidden)
mine vibrated the car on interstate at like 1/2 - full throttle.
Old Mar 25, 2003 | 05:11 PM
illusion's Avatar
cv boot?
Old Mar 26, 2003 | 02:02 AM
driveshaftshop's Avatar
hey
i would have to agree with 4bidden, the axle has no bearring tyep faster and slower rotating internal parts. i would check the brakes and thewheel bearring.
frank
Old Mar 26, 2003 | 05:47 AM
93ludeSi's Avatar
Default Re: Is it the Axle? (driveshaftshop)
If it is clicking at all when you turn it is a dead give away that it is the axle CV joint
Old Apr 18, 2003 | 09:10 AM
C-Murdock's Avatar
Default Re: Is it the Axle? (93ludeSi)
the front of my car shakes as well, really bad from 1/2 to full throttle...did you ever figure out what was wrong with yours boosted ?
Old Apr 21, 2003 | 07:31 PM
C-Murdock's Avatar
Default Re: Is it the Axle? (C-Redrum)
ttt
Old Apr 21, 2003 | 08:02 PM
del_parker's Avatar
it could be one of the bearings/plates inside the cv joint. one of mine cracked and would do what you're describing.
edit: well, i re-read your post, and i'm not so sure about the "cold" "warm" part. mine did it no matter what.
Old Apr 21, 2003 | 08:18 PM
Prelude Vtec 23's Avatar
Default Re: Is it the Axle? (illusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusion &raquo;</TD></TR><TR><TD CLASS="quote">cv boot?</TD></TR></TABLE>
First thing first.......check the basics, see if it is your cv boot, if you leave like that then it can do further damage and cost you more like replacing your axles.
LudeJdm
Jun 2, 2005 11:50 PM
MOTOCOMPO
Sep 30, 2004 09:26 PM
Rocks
Jun 28, 2004 11:06 AM
GReddy SI
12
Jul 17, 2003 04:07 AM
maskedSONY
May 2, 2003 04:52 AM
