Have an issue with my car lossing power
So my 96 prelude has just started to act up the past 3 weeks it seems to be losing power like something is restricting it but I checked the cat and it isn't clogged and cleaned the egr and ports and the throttle body, can yall help me out.
Welcome to the club I have had this same issue ever since I did the swap there could many things to cause this issue. Like fuel pressure regulator, intake air temperature sensor, map sensor, timing belt skipped a tooth, bad o2 sensor, clogged fuel filter, bad engine temp sensor, faulty cap and rotor on dizzy or the icm in the dizzy is on its way out.
auto moto
Dec 28, 2005 05:45 PM
SkRiBLaH
Nov 14, 2004 07:34 PM
