Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Low idle when hot
Old Apr 17, 2015 | 02:03 PM
ThaLidoOne's Avatar
Default Low idle when hot
Motor:d17a1 automatic, 120k
Now it always happens when i'm coming to a complete stop (ex. red light, stop sign, traffic lol)
When hot, the car normally idles around ~500rpm. I wanna note that the car doesn't die all the time about 1/5 of the time. But the other 4/5 the idle goes below its normal ( to about 100rpm) and chokes its way back up to ~500rpm or with the help of me adding gas.
Somethings ive been thinking of doing but anything would be helpful.
-Change Air Filter
-Clean IACV Valve
-Open the Idle Screw up
Thanks in advance!
Old Apr 19, 2015 | 04:54 AM
lazlong's Avatar
Default Re: Low idle when hot
500 rpm is low already, you should be at 700+/- 50 rpm. First thing to do is check for codes. If no codes, clean or replace the IACV and clean the trottlebody. A new filter isn't a bad idea.
Old Jun 1, 2015 | 04:00 AM
sebastianinigo's Avatar
i have same problem.
check your PCV valve as well and o2 sensor at TDC sensor.
Bocan
Honda Civic (2006 - 2015)
20
Aug 15, 2014 05:05 PM
phatbuddha
May 20, 2013 10:46 AM
the.hamburglar
May 10, 2007 08:46 PM
ph0shizzle
26
Aug 7, 2006 10:00 AM
Joon Joon
24
Oct 26, 2004 07:06 AM
