idle problem
Old Jan 30, 2013 | 02:13 PM
phatbuddha's Avatar
Default idle problem
i just recently picked up a 96 gsr and today the idle started to jump from 800 to 1500 rpm. Any thoughts on whats going on? help plz
Old Jan 31, 2013 | 12:59 AM
ahtublao's Avatar
Default Re: idle problem
any cel? clean your iacv and fitv. might be a bad fuel filter as well. i just put a new one in my car and it idles good now but it never jumped to 1500rpms. mine was bogging and had a low idle.
Old Jan 31, 2013 | 04:34 AM
phatbuddha's Avatar
nope, no cel in on. Also, sometimes it even stop jumping idle when im at a red and start again.
Old Jan 31, 2013 | 04:41 AM
ahtublao's Avatar
yeah try changing out your fuel filter. i had an issue where my gsr would bog when driving and at idle it will bog then the car dies. i didnt have any cel's either which made me think that it was the fuel filter. cause anything else would throw a code like tps and map sensors. but clean your iacv and fitv. it helps a lot with idle issues and makes the car breathe better.
Old Jan 31, 2013 | 07:06 AM
GagnarTheUnruly's Avatar
IACV malfunction, vacuum leak, and bubbles in coolant are the most common causes of a fluctuating idle. Clean the IACV, bleed the coolant, and check for vacuum leaks, in that order.
Old Jan 31, 2013 | 11:51 AM
LoveMyteggy's Avatar
Most likely to be your fuel filter had same problem with my 94 teggy.
Old Feb 4, 2013 | 12:04 PM
phatbuddha's Avatar
I change my fuel filter and it fixed the idle problem. thanks for the diagnostics guys
Old Feb 4, 2013 | 04:45 PM
oakteg21's Avatar
Iacv most common problem for integras when it comes to idle
Old May 20, 2013 | 10:46 AM
hwyix's Avatar
Originally Posted by GagnarTheUnruly
Clean the IACV,
I assume this one.
( Your IACV a.k.a. Idle Air Control Valve )
https://honda-tech.com/forums/showth...highlight=idle
or did you mean this one or do both?
(Clean Your FITV aka Fast Idle Thermo Valve)
Hyde1
24
Apr 8, 2013 09:59 AM
pfsmith99
Oct 14, 2012 09:02 AM
SHG_James
Feb 13, 2009 04:40 PM
pjr710
12
Jul 5, 2008 09:03 PM
maxxdout
Jun 21, 2002 06:04 AM
