how do you test a p28 ecu?
Old Apr 5, 2015 | 03:21 PM
nyckid's Avatar
Default how do you test a p28 ecu? TRYING TO TROUBLE SHOOT NO START
is there a way to test a ecu to see if its good or not? trying to trouble shoot my no start
fuel pump primes and i loosened the fuel filter screw and gas sprays out
not getting spark
new main relay
new icm
new coil
new battery
new cap
new rotor
all fuses are good. getting power to the dizzy from the blk/yellow cable
Old Apr 5, 2015 | 05:40 PM
RepumIntegra's Avatar
Default Re: how do you test a p28 ecu?
plug it in the vehicle and see if it starts.
Old Apr 5, 2015 | 06:07 PM
B_Swapped93's Avatar
it either works or it doesn't simple as that.
Old Apr 6, 2015 | 08:21 AM
nyckid's Avatar
ttt
Old Apr 6, 2015 | 11:37 AM
are you hearing the fuel pump prime? Are you getting any spark?
Old Apr 6, 2015 | 01:56 PM
nyckid's Avatar
not getting spark
new main relay
new icm
new coil
new battery
new cap
new rotor
Old Apr 7, 2015 | 09:43 AM
nyckid's Avatar
BUMP
Old Apr 7, 2015 | 03:14 PM
fcm's Avatar
fcm
Old Fart
Check for power at IGP1 and IGP2 at the ECU/ECM with ign. on.
Check for power to the distributor assembly.
MM&Y of car would help???? 94
Old Apr 7, 2015 | 04:17 PM
nyckid's Avatar
90-TEG B20/B16
DIZZY GETS POWER/ECU GETS POWER. IVE CHANGED ALL THE STUFF THATS MENTIONED ABOVE. STILL NO SPARK
Old Apr 7, 2015 | 10:11 PM
Are you getting any power to the dizzy as you crank the car?
Old Apr 8, 2015 | 09:17 AM
nyckid's Avatar
no power comes out of the dizzy
Old Apr 8, 2015 | 09:45 AM
Alright same thing happened to me two weeks ago. its a fuse. The underdash fuse box is where you want to look. There are 2 fuses separated from the pack. on top of those fuses is the ignition switch harness (for reference) it is the fuse on the left. let me know if that is the problem.
I had to buy another dizzy ($100) and another external coil ($60) and problem was a simple 15 amp fuse.
Old Apr 8, 2015 | 11:56 AM
nyckid's Avatar
what do you mean 2 fuses that are separate from the pack? all my fuses in the the box is is good same for the engine bay
Old Apr 8, 2015 | 10:04 PM
dang my bad, I was thinking of the 3rd gen integra and you have a 93 integra. the only other thing I can think of is checking your grounds, the one on the thermostat and the other on the transmission to chassis.
Old Apr 9, 2015 | 03:57 PM
nyckid's Avatar
bump
Old Apr 10, 2015 | 08:38 PM
Any other ECU you have tried?
Joe Sauls
Feb 17, 2018 01:50 AM
nyckid
Apr 7, 2015 06:29 AM
steven83r
Oct 21, 2013 07:21 AM
NL826
15
Jan 23, 2010 12:22 PM
dsrconcepts
Feb 27, 2005 09:13 AM
