Opening connectors
Old Mar 25, 2015 | 06:27 PM
1990IntegraLS's Avatar
Icon2 Opening connectors
This is an old Integra and many of the connectors are a bit brittle. It isn't helping that I can't find info on how they open. There's many different ones. So far just about every one I've had to undo gets broken.
Right now, I'm just trying to get the 8p and 2p on the distributor. They're upside down and I can't see how they work. I've already broken the 2p.
Anybody know where there some data on how the connectors open?
Thanks!
Old Mar 26, 2015 | 03:04 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Opening connectors
Disconnecting or unpinning?
Old Mar 26, 2015 | 05:19 PM
Just disconnected. Sounds dumb, I know. So far I've broken nearly every connector I've had to undo. ...haven't lost any yet, but broken the latch on the sides......
These are the 2p and 8p connecting the distributor. No data I can find on how to open (disconnect) them.
These two are different then any I've seen elsewhere.
Old Mar 26, 2015 | 05:59 PM
B_Swapped93's Avatar
I've had trouble with old plugs best bet get some nitrile gloves and grip as hard as you can, next COMPLETELY remove the clips from each plug and gently use channel locks to pull them apart. The last suggestion is an acquired skill don't do it unless you fell comfortable with how much pressure you apply. When trying by hand use your thumb and index finger to try and wiggle them (in both hands) you'll see what I mean when you try they're pretty tough but don't pull near the wires AT ALL.
Old Mar 26, 2015 | 06:11 PM
Yes, unfortunately one of my thumbs is ruined, so I can't use it near full strength.
What about a source for new or different connectors.....?
Old Mar 26, 2015 | 06:15 PM
you're talking about the 2 distributor plugs right?, splicing in a new plug would be a big hassle. but if that's what you mean a junk yard or splice each wire one at a time and eliminate the plug but I don't recommend that.
Old Mar 26, 2015 | 06:24 PM
I think you're right, but I even thought about bullet connectors. The wires aren't really long enough. I'd have to put new wires from inside the distributor. I've done lots of bullets connectors on many motorcycles. I'll try and get the plugs undone.
The 8p is very different. I have no idea how to unlock it.
Old Mar 26, 2015 | 06:34 PM
post a pic of the plug clamps? I know the obd0 ones are round I just cant find a good pic online, could possible give a better suggestion that way.
best suggestion I have is remove any remaining part of the snap clamps I circled them in orange and use some pliers with a cloth in between the bite and the plug and pull they are just slip connectors. But those clamps on the round plugs are hard/
Old Mar 26, 2015 | 06:55 PM
No visible snap clamps on the outside of mine. That's why I don't know what to do. I could take a photo. I'll take a photo and put it here. Might take a while.
Old Mar 26, 2015 | 07:26 PM
Ok there is some side latch or something, but I don't think that's what disconnects it. There's another tab at the bottom, I'm guessing you've got to depress them on each side. Sorry, not well lit. I haven't taken them off the distributor mount because I don't want to move the harness wires around unless I have to.
Old Mar 26, 2015 | 07:32 PM
i would resort to a flat head and press and pry in the slots as far down as possible, sorry i can't help more i've never seen plugs like that.
Old Mar 26, 2015 | 07:33 PM
Yeah obd0 I guess. Thanks!
..know any body that might?
Old Mar 26, 2015 | 07:36 PM
more people browse the forum during the day, you can bump it if it doesn't get a reply by late afternoon tomorrow.
Old Mar 27, 2015 | 04:56 AM
Technical Hero
As a general rule its much easier to separate them if you take them off the metal clip first.
Old Mar 27, 2015 | 05:27 AM
Yes thanks, but how? The tabs on the bottom?
builthatch
10
Jun 19, 2014 01:37 PM
silvay
Jan 25, 2010 10:43 AM
Nataku
Dec 18, 2006 03:13 PM
AutoEuphoria
Feb 24, 2005 10:37 AM
EFSiR
Jan 24, 2002 08:33 PM
