NEED HELP - D16Y8 OIL LEAK
Can you take another picture around the distributor on the left of the upper radiator hose.
You could also clean up the area and go for a drive get the car nice and hot. park it and leave it running and see if you see any new oil or leaks.
Here are the pictures sorry for the time I took to post them I got real busy.
I cleaned the engine where the oil was seeping through and it was bone dry until I checked it again today and it is leaking in the same place like around the distributor area any ideas what it could be? I barely changed the oil a week prior when I noticed the leaking.
P.s Thanks for the help I really appreciate it!
Take the distributor cap off and check inside for oil. If dry change the distributor to cylinder head o-ring. If wet you will need to change both. The inside o-ring requires dis-assembly of the distributor.
Thanks! I will try tomorrow forsure I was looking on ebay for the o rings and I came across these Honda Accord Civic Acura Integra Distributor O Ring Seal NOK Ishino | eBayWill these get the job done?
Sorry This is my first civic aha
The easiest and fastest method is stop in to your local Honda dealer and order the seal. It will only cost you a few bucks (5 tops) and you won't have to pay shipping and your dealer will have it next day unlike eBay where you will wait at least 5 business days unless you pay a premium.
I ordered a handful of seals on Friday morning and they had them by Saturday morning for me to do my work that weekend.
I took the distributor off and noticed it didn't have the o ring so I put the new o ring on and i drove the car and i checked it two days after and its still leaking around that area shown in the pictures, what else can it be?
Grr So I was wrong I thought the leak had stopped but it is still leaking from the same spot which Is shwn in the pictures, I did the valve cover gasket and distributor anything else It Could Be?
I think I have the same problem he is having with my D16Y7, and I think its coming from the Distributor. I am going to order new caps and rotors and a new seal/o ring gasket kit.
alecmesa96
Jun 18, 2023 04:48 PM
brios86
12
Nov 29, 2011 10:29 PM
ibemike
May 16, 2006 03:00 AM
