2002 Accord, Manual - Clutch sticks to floor
Old Mar 17, 2015 | 07:38 AM
adknate's Avatar
Default 2002 Accord, Manual - Clutch sticks to floor
Quick question in regards to my clutch problem.
I let my friend borrow my car overnight and he brought it back reporting to me that the clutch was sticking to the floor (unengaged, for the most part.) I was able to drive it home by starting in second and once I picked up speed could shift by lifting the clutch pedal with my toe.
The fluid reservoir is full and I can't see any visible leaks. However, the fluid is dirty.
I plan on replacing the Clutch Master and Slave. The question is: most everything I've read online reports that the cylinders going bad is a gradual process. I've had the clutch stick once or twice before, but not in several months before my friend drove it. Should I be preparing for something else being the problem?
Old Mar 17, 2015 | 10:24 AM
holmesnmanny's Avatar
It should never stick to the floor. Its likely there is an air bubble in the line that only manifests itself at times.
If it were me i would swap out the mc with an exedy anyhow.
Old Mar 18, 2015 | 07:44 AM
adknate's Avatar
Default Re: 2002 Accord, Manual - Clutch sticks to floor
Thanks, I'll try bleeding it first.
tercelrcr
Feb 2, 2013 06:25 AM
88crxdxfastwhip
Jun 5, 2007 01:05 PM
Jack Black
Feb 18, 2005 11:30 AM
arielb1
Jul 26, 2004 05:54 PM
2ksi
Aug 12, 2003 04:45 PM
