need help asap :(
Old Feb 5, 2015 | 09:25 AM
hondaciviceg4dr's Avatar
Default need help asap :(
Okay guys so i saw my car has a p28 ecu but the engine is a d16y8 im having issues with it feeling really weak under 3k rpm do you guys think its bc of the ecu also what ecu should i get for my engine d16y8 i believe the car had a d16z6 i think the engine harness is stock too also the car used to be automatic i checked the ecu codes i got map sensor 3 quick flashes then i also got 5 quick flashes wich is map sensor then i got vtec spool valve then i got primary oxygen sensor heater mind you my car is straight piped and theres no cat or o2 sensor down their thanks
Old Feb 5, 2015 | 09:26 AM
You summ bitch admins
Okay guys so i saw my car has a p28 ecu but the engine is a d16y8 im having issues with it feeling really weak under 3k rpm do you guys think its bc of the ecu also what ecu should i get for my engine d16y8 i believe the car had a d16z6 i think the engine harness is stock too also the car used to be automatic i checked the ecu codes i got map sensor 3 quick flashes then i also got 5 quick flashes wich is map sensor then i got vtec spool valve then i got primary oxygen sensor heater mind you my car is straight piped and theres no cat or o2 sensor down their coould the map sensor be causing my issue
Old Feb 5, 2015 | 09:27 AM
ejv8s10's Avatar
Default Re: need help asap :(
Calling names, not reading the rules and asking for help?
Good Luck!
Old Feb 5, 2015 | 09:29 AM
Oops i acidently did that my bad sorry i copied and pasted on accident
Old Feb 5, 2015 | 09:37 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
30 day vacation for you my friend.
I don't think that's a proper way to start a need help thread.
You can try again in 30 days.
Merged threads for cleanup and evidence of misconduct.
Old Feb 5, 2015 | 10:30 AM
tony_2018's Avatar
Fish Twig
This dude is jumping around..........cel codes wrong
Brandon myers
Mar 23, 2016 10:36 AM
hondaciviceg4dr
Engine Management and Tuning
Feb 5, 2015 01:32 AM
SL0RD
21
May 13, 2012 06:09 PM
sohctodohc
12
Nov 9, 2007 12:37 PM
bmoua
Apr 15, 2007 12:24 AM
