need help asap :(
Okay guys so i saw my car has a p28 ecu but the engine is a d16y8 im having issues with it feeling really weak under 3k rpm do you guys think its bc of the ecu also what ecu should i get for my engine d16y8 i believe the car had a d16z6 i think the engine harness is stock too also the car used to be automatic i checked the ecu codes i got map sensor 3 quick flashes then i also got 5 quick flashes wich is map sensor then i got vtec spool valve then i got primary oxygen sensor heater mind you my car is straight piped and theres no cat or o2 sensor down their thanks
need help asap :(
You summ bitch admins
Okay guys so i saw my car has a p28 ecu but the engine is a d16y8 im having issues with it feeling really weak under 3k rpm do you guys think its bc of the ecu also what ecu should i get for my engine d16y8 i believe the car had a d16z6 i think the engine harness is stock too also the car used to be automatic i checked the ecu codes i got map sensor 3 quick flashes then i also got 5 quick flashes wich is map sensor then i got vtec spool valve then i got primary oxygen sensor heater mind you my car is straight piped and theres no cat or o2 sensor down their coould the map sensor be causing my issue |
Re: need help asap :(
Calling names, not reading the rules and asking for help?
Good Luck! |
Oops i acidently did that my bad sorry i copied and pasted on accident
Originally Posted by hondaciviceg4dr
(Post 50193389)
Okay guys so i saw my car has a p28 ecu but the engine is a d16y8 im having issues with it feeling really weak under 3k rpm do you guys think its bc of the ecu also what ecu should i get for my engine d16y8 i believe the car had a d16z6 i think the engine harness is stock too also the car used to be automatic i checked the ecu codes i got map sensor 3 quick flashes then i also got 5 quick flashes wich is map sensor then i got vtec spool valve then i got primary oxygen sensor heater mind you my car is straight piped and theres no cat or o2 sensor down their coould the map sensor be causing my issue I don't think that's a proper way to start a need help thread. You can try again in 30 days. Merged threads for cleanup and evidence of misconduct. |
This dude is jumping around..........cel codes wrong
