D16y7 swap into 93 civic
I have a 93 civic with a blown d15 auto. I also have a 98 civic manual doner car. 111xxx on y7, both cars are sedans. I have a few questions about the swap befor I start.
Will the shift linkage match up?
I know I need to rewire the dizzy but what about the engine harness can I get a z6 one or and adapter??
Also will a z6 manual ecu work?
Can I use the peddles form 98 in the 93?
And do I have to get obd1 manual starter or will the one one the d16 work?
I think that's all for now, hope some one can help me need to get on this asap!!
Use the harness, distributor, complete intake and exhaust manifolds and alternator from the b7. swap timing belt side the post mount over and you will need a auto to manual trans mount. I think you will also need a 92-95 manual tbracket mount as I dont think the 96-00 bracket will work in a 92-95 chassis. You can ether get a manual po6 ecu or convert the one you have to manual.
Starter will work fine. Im not sure about the shift linkage or peddles as im a 92-95 guy but i think they will work.
Also thank you big help!!
bestofthe80s
Nov 5, 2017 03:16 PM
garados
Sep 30, 2017 06:42 AM
slammedstd
Jun 11, 2008 01:41 PM
furiouscivic
Jul 28, 2006 02:40 AM
