want to do a automatic to manual swap 92-95 hatch
I'v never done it before just wondering if i will run into any problems with starting the engine i'm puting a z6 in it any suggestions would really help thanks
Re: want to do a automatic to manual swap 92-95 hatch (slammedstd)
you should have no problems starting the car if you have a mt ecu...you did make sure you got the clutch petal, shift lingage, ect... right?
once you install the ecu and everything there wont be a lock..thats why you need a manual ecu not an suto for that reason and others like overdrive
you should be able to use the si tranny mount but im not sure someone else will probally chime in with more info
wannab20hatch
08-21-2002 07:03 PM
