Low idle car won't warm up.
Old Feb 2, 2015 | 02:41 PM
Fraser1989's Avatar
Default Low idle car won't warm up.
Hey guys,
I have done some searching but I cannot find a combination of both my problems.
So I have a 1999 civic CX hatch. When I start my car in the morning it idles at 1000ish RPM then it drops to around 500RPM. While it is not a rough idle or wanting to stall it does seem low.
Now my only real reason for concern is the car won't warm up. I live in Alberta where it is regularly -20 to -35 C so it is nice to let the car warm up in the morning.
So my problem is with the low idle the car won't get above 63C/145F. Also it is plugged in at that time. Naturally I would assume the thermostat is no good it is clearly working as the car gets to the proper temp when running and does not overheat. However, when I am not on the gas the temperature will regularly fall to 70C/158F.
I have no codes and am not really sure what is causing this. I have cleaned everything, new spark plugs, wires and distributor.
Also in my searching I have seen a lot of guys with the same problem, but not much for solutions. Any ideas?
Old Feb 2, 2015 | 02:51 PM
White_EG1's Avatar
Default Re: Low idle car won't warm up.
The stock idle speed for the d15z1 is 420 + - 20 straight from the service manual.
Old Feb 2, 2015 | 02:54 PM
Fraser1989's Avatar
Its a D16y7 if that matters.
Old Feb 2, 2015 | 02:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
Your thermostat could also be stuck open. It's supposed to close when your coolant reaches a certain low temperature, to keep the coolant within operating range.
Old Feb 2, 2015 | 03:38 PM
Fraser1989's Avatar
I doubt it as the car maintains a normal operating temperature when driving.
Previously in the past when I have had a car with the thermostat stuck open it cooled the engine quickly when driving in -20
Old Feb 2, 2015 | 06:20 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Move to Florida.
eH.
Old Feb 3, 2015 | 05:17 AM
Fraser1989's Avatar
Originally Posted by eHMxhACk
Move to Florida.
eH.
Car has no AC. Then I would have a whole new set of problems.
intenseEK
Apr 13, 2009 07:13 AM
CircuitFG
May 13, 2005 06:05 PM
SoloSol
Dec 26, 2001 07:06 PM
