how can I set my rev limiter?
Old Jan 31, 2015 | 04:13 PM
scopp's Avatar
Default how can I set my rev limiter?
I have a 92 civic dx hatch with a turbo d16y7, and the rev limiter is set for 3500 rpm, which gets really annoying. Is there anyway to adjust this? I know that the motor should hit limiter above 6000 rpm
Old Jan 31, 2015 | 05:05 PM
theYBLEGAL's Avatar
Loved
Default Re: how can I set my rev limiter?
3500 ish sounds like it's in a fail-safe mode.
Without knowing any other details about your car, assuming your ECU is modified, and you should go find someone to physically take a look at things.
Chip inside ECU may not be making a good connection. May not be tuned. Is the car new to you?
First impression is telling me you need someone else to help you. No offense.
Old Jan 31, 2015 | 05:18 PM
Muckman's Avatar
Moderator in Chief
Is your check engine light on?
Old Jan 31, 2015 | 05:32 PM
blackeg's Avatar
sounds like either limp mode, the person you got the ecu from screwed you, or in general its not tuned and they dont want you ripping on it.
what ecu is it, what program is it running, and like muckman said, is your check engine light on?
Old Feb 1, 2015 | 08:12 PM
scopp's Avatar
All this ECU and chiping stuff is just confusing to me. Is there anywhere you would recommend I take it that wouldn't be too expensive?
Old Feb 1, 2015 | 08:13 PM
scopp's Avatar
Yeah, but I think that's because I don't have a catalytic converter
Old Feb 2, 2015 | 11:23 AM
theYBLEGAL's Avatar
Loved
Honda-tech actually has a sticky for that. But no worries,
https://honda-tech.com/engine-manage...ctory-2368887/
The list may have outdated information. Not sure how maintained it is.
If you post your location, maybe someone can chime in with personal experience somewhere.
I'm in Chicagoland area myself. Would recommend iLL Garage, or RC Autoworks. Weather or not that helps...
Old Feb 2, 2015 | 11:41 AM
spAdam's Avatar
Loved
Community Favorite
No. Your car is obd1 and wouldn't know the difference.
Don't think, know.
Check your codes by jumping the blue 2 pin connector by the ecu and go from there.
Old Feb 3, 2015 | 06:11 PM
GhostAccord's Avatar
Based on your initial information I would guess that you are running on a stock ECU that is in limp mode or possibly a modified ECU that isn't running a proper tune.
Without knowing anything about who put your build together and whether or not it has even been tuned or the ECU modified. It makes it difficult to give you any real helpful information. Only information I can pass on would be for you to call around to local shops or find local forums that might know of someone who tunes Honda's. Your best bet will be to take this thing to someone who can take a look at it and at least be able to tell you what you have and what it's going to take to get it running properly.
Old Feb 3, 2015 | 06:32 PM
theYBLEGAL's Avatar
Loved
Old Feb 4, 2015 | 05:30 AM
Treyschls's Avatar
lol ^
Old Feb 4, 2015 | 05:37 AM
Treyschls's Avatar
Are you sure its the rev limiter.? If your not 100% watch a video on youtube to make sure that's what your experiencing...
Also does your engine have Vtec.?
98greensi
Mar 5, 2012 04:07 PM
stiffymeister28
Jun 10, 2011 08:22 AM
tenchi r
Mar 6, 2010 10:45 AM
94dxt
Mar 26, 2003 03:29 PM
