Speedometer issues
Old Jan 26, 2015 | 12:01 PM
teamleader's Avatar
Default Speedometer issues
I searched the old post and couldn't get the right info, so here goes. I have a 93 delsol, d16z6 manual.car sat for 5 years before I bought it.the speedometer isn't working. At first the odometer worked but no speedometer.Now neither work. Tach and every thing else work fine.If I pull the vss out and put a drill on it it works, but you have to spin real fast.the gear in the trans looks fine and spins,what should I check?
Old Jan 26, 2015 | 01:33 PM
Former User's Avatar
Default Re: Speedometer issues
What is it? The speedometer?
Is CEL code 17 thrown?
Is the drive link installed?
Old Jan 26, 2015 | 05:20 PM
teamleader's Avatar
Yes has the drive link,is it magnetic activated?is it susposed to go up and down? Throws no codes,but the check engine light comes on after 5-10 minutes of driving.when you turn the car off and restart it the lights gone .
Old Jan 26, 2015 | 05:21 PM
Need answer.
When CEL turns on, don't turn engine off and jump service connector.
Old Jan 26, 2015 | 05:35 PM
teamleader's Avatar
What is the service connector?
Old Jan 26, 2015 | 05:37 PM
For pulling CEL codes - click the link in my signature.
Old Jan 26, 2015 | 11:03 PM
moderu's Avatar
If your RPM works but you don't have speed reading, it could just be your speed sensor.
Old Jan 27, 2015 | 08:41 AM
teamleader's Avatar
Yea but I tried 4 different ones, all used though.
Old Jan 27, 2015 | 08:52 AM
teamleader's Avatar
Ronj@HT thanks I will try and pull codes when I get home.
Old Feb 1, 2015 | 11:36 AM
teamleader's Avatar
Code 43 fuel system
Old Feb 1, 2015 | 01:02 PM
teamleader's Avatar
Speedometer stared working,I think it was a issue with wires and a bad speedometer.now just a fuel problem.
david2450
22
Jan 23, 2013 06:37 AM
ChrisHinds
Apr 29, 2010 08:58 PM
krazieV
Aug 7, 2008 08:43 PM
TMaccord91
Oct 6, 2004 09:30 PM
.Noah Fecks
Jun 26, 2003 11:21 AM
