Car chokes when I ask for more gas and smokes comes out
Old Jan 23, 2015 | 09:48 PM
Danny_barca's Avatar
Default Car chokes when I ask for more gas and smokes comes out
I have a 2002 Honda accord 2.3. For some reason when I want more power and I step on it the car chokes and smoke starts coming out of the muffler. When I stop and try to take off again it just doesn't go. It chokes. What can it be?
Old Jan 23, 2015 | 11:09 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Car chokes when I ask for more gas and smokes comes out
What color smoke?
Does your check engine light work? Is it on? Do you checked for any stored codes?
Back probe the MAP sensor and watch the voltage readout, if you have a vacuum pump that would be best. Turn the car to on, back probe the MAP and apply vacuum to the MAP, it should have a lineaer voltage change.
Back probe the TPS, it should have a linear voltage change.
What is the fuel pressure?
Does the car do this both when it is cold and hot?
Does your temp gauge function?
Pull your spark plugs and check.
Is your car an AT or MT?
If you leave it in 1st does the car still bog?
Old Jan 24, 2015 | 06:36 AM
Originally Posted by MAD_MIKE
What color smoke?
Yeah my check engine light went on like for 2 days then it turned off. It's automatic. It does it when it's cold or hot. Temperature gauge works.
Old Jan 24, 2015 | 07:03 AM
B20VtecVillain's Avatar
What color smoke? If it's black smoke I would say your having an issue with losing spark.
When was the last time spark plugs/wires were checked or changed? Also, plug in and read those codes from what made the CEL come on for those few days. If the code thrown was for a sensor, that may likely be the culprit.
Old Jan 24, 2015 | 07:39 AM
Yeah it's like black smoke. I have no idea. I just bought the car about 2 weeks ago. And it does it when it reaches 4,000 rpm. Yeah I would have to put it on the computer and see what codes come out. U think this can b y the car is killing so much gas 2?
Old Jan 24, 2015 | 08:04 PM
MAD_MIKE's Avatar
MM Gruppe B
What was the code?
Old Jan 25, 2015 | 12:41 PM
Murphy84's Avatar
Vtech engine? The vtech system malfunctioning can do this. Just an idea since I had a similar problem and it was the solenoid for the vtech system. Check your codes, if none are stored I'd say drive it and try to get the engine light on and check it right away. The light shuts off after a while when it doesn't detect a problem anymore.
Old Jan 25, 2015 | 01:28 PM
Even after the MIL goes out it should still store the codes it threw in the history and should come up when you scan.
Old Jan 25, 2015 | 01:41 PM
Murphy84's Avatar
Not always, at least not with my car.
Old Jan 25, 2015 | 07:50 PM
MAD_MIKE's Avatar
MM Gruppe B
Then your memory fuse is blown, or your ECU is buggered. ECU/PCM does not self clear if a code goes away.
Old Jan 26, 2015 | 06:46 PM
Murphy84's Avatar
Fuses are fine and I'm not all that worried about it. The car drives fine with the exception of my brake issue and a misfire that'll take about 5 minutes to diagnose and fix when I figure the brake thing out which to me is more important.
Old Jan 26, 2015 | 06:56 PM
MAD_MIKE's Avatar
MM Gruppe B
If your memory fuse is not blown and the PCM is not storing codes, then your PCM is probably CAUSING problems.
Old Jan 26, 2015 | 07:27 PM
Murphy84's Avatar
I guess it's possible but I don't have many problems often to begin with. It stores codes though, just not generally after the light goes out on it's own. I haven't let that happen in over a year though.
Old Jan 27, 2015 | 01:00 AM
holmesnmanny's Avatar
OP pull the codes .. it should tell you which sensor is putting you into limp mode.
liftdhatch95
Dec 24, 2007 12:17 PM
Stevegunit16
10
Feb 14, 2007 07:21 PM
sloaccrd
Jun 21, 2005 09:46 PM
slowEm2
Nov 9, 2004 11:02 PM
threatcon13
Dec 6, 2001 07:50 AM
