Cant set timing 93 accord
Old Jan 21, 2015 | 08:21 AM
bdr_one's Avatar
Default Cant set timing 93 accord
I tried today to adjust my timing cause of valve noise.I hooked up a timing light,ran engine to operating temp,jumped the plug at the kick panel,loosened dizzy,removed the rubber plug.Found the timing is way off moved the dizzy and it wouldnt move no more.Checked with timing light and is still off.If I take out the dizzy bolts I believe I can set the timing.But the dizzy bolts wont line up.Anyone have any suggestions on what is wrong.Could the timing belt be a few notches off?I checked he firing order and its correct.
Old Jan 21, 2015 | 08:54 AM
holmesnmanny's Avatar
Is it hooked up to the number 1 spark plug wire (driver side cylinder) ?
Old Jan 21, 2015 | 09:03 AM
bdr_one's Avatar
Default Re: Cant set timing 93 accord
Yes double checked it
Old Jan 21, 2015 | 09:18 AM
rockycat's Avatar
Could it be you are still auto timing, jump not correct.
Old Jan 21, 2015 | 09:32 AM
bdr_one's Avatar
Dont know what you mean by auto timing
Old Jan 21, 2015 | 10:02 AM
MAD_MIKE's Avatar
MM Gruppe B
If your jumper wire is not conducting the CEL will not be lit and the timing is still going to be adjusted by the ECU. Can usually tell if the jumper is working by watching the base timing, if it is steady the jumper is working, if it still jumps around the ECU still has control.
If the timing is stable and not adjusting but the timing is off recheck the camshaft timing belt adjustment, it is either not correctly timed or the tensioner on the timing belt has loosened and allowed slop/retarded timing.
Old Jan 21, 2015 | 10:17 AM
rockycat's Avatar
If by "valve noise" you mean ping under load the first do as MAD MIKE posted and if all is good and base timing is ok and you still have ping then remember the computer does the timing so get better gas.
Old Jan 21, 2015 | 11:18 AM
bdr_one's Avatar
Ok I check it all again the timing wasn't jumping around it stayed in one spot I'm thinking the belt has slipped
Old Jan 21, 2015 | 06:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Check the big acorn nut on the timing cover. It should not be loose, if it is you have found your problem.
Old Jan 21, 2015 | 07:08 PM
10psiLsEf2's Avatar
maybe mechanical timing is off
Old Jan 22, 2015 | 09:21 AM
bdr_one's Avatar
I dont see a alcorn nut been all over the timing cover.
Old Jan 22, 2015 | 12:39 PM
76 camaro car's Avatar
Acorn nut should be below the motor mount coming through the timing cover on a 4cyl.
Old Jan 22, 2015 | 01:25 PM
MAD_MIKE's Avatar
MM Gruppe B
Yellow arrow.
Old Jan 22, 2015 | 05:56 PM
bdr_one's Avatar
What the purpose for the nut is it a tensioner nut or something
Old Jan 22, 2015 | 07:12 PM
rockycat's Avatar
It is to tension the tbelt. Find and follow the proper way to do that.
Old Jan 22, 2015 | 08:35 PM
It really gets old seeing all these ******* noobs tryin to give out advice when they dont know **** about these cars and even worse to see noobs askin questions they think they already know the answers to.
Old Jan 23, 2015 | 07:18 AM
rockycat's Avatar
May be a "noob" by thread count but Honda has seen fit to give me Master tech status.
Old Jan 23, 2015 | 10:20 AM
MAD_MIKE's Avatar
MM Gruppe B
When setting tension on the belt, that nut locks down the timing belt idlers. Installer never physically tightens the belt, that is the job of the spring loaded idlers.
If that nut comes loose the idlers will be allowed to move, causing slack in the belt and disrupting cam/ignition timing.
Old Jan 23, 2015 | 11:18 AM
MaTak87's Avatar
Also scary to think of damage they could when giving out wrong or just plain bad "advice"
Old Jan 29, 2015 | 07:39 AM
bdr_one's Avatar
Well I have tore the timing cover off and found the timing belt looks like it had been replaced.Lined up the crankshaft ,and looked at where the cam was sitting according to the marks.I have found the problem to why the engine cant be timed.The cam appeared to be a couple of teeth off.Hopefully when I get this thing together I can get the dizzy timed right and the misfire feeling will be gone.
Old Jan 30, 2015 | 11:57 AM
bdr_one's Avatar
Does anybody know if the tension idler have a washer behind the acorn nut
Old Jan 30, 2015 | 08:20 PM
Treyschls's Avatar
some look like this
Old Jan 30, 2015 | 08:24 PM
MAD_MIKE's Avatar
MM Gruppe B
No washer. But the groove on the nut retains a rubber washer grommet that seals the timing belt cover to nut. #27 90401-PT0-000 ~$3
Old Feb 1, 2015 | 11:39 AM
bdr_one's Avatar
Replaced the timing belt and oil pump belt ,Now I dont have much tension on the oil pump belt.I think the springs are bad on the tensioners .Did i put the springs in the wrong place
Pancho2193
Mar 13, 2013 10:38 AM
fastrat37
Dec 24, 2012 03:49 PM
matbh22a
Jun 19, 2007 12:15 PM
Nextelbuddy
Mar 30, 2004 10:09 AM
