Alternator On its Way Out? 00 Civic EX
Old Jan 14, 2015 | 05:19 PM
mimog3's Avatar
10 Year Member
Default Alternator On its Way Out? 00 Civic EX
Hey everyone, got a 2000 Civic EX with 196k and it seems like the alternator is on its way out.
Engine is stock other than a Cold Air intake, I do have a projector retrofit in the car with a 35w HID kit with a relay harness. also have a aftermarket stereo system. other than that the car is like any other civic on the road.
I have been having issues with the lights flickering inside and out of the car. by flickering i mean dimming in and out and occasionally the lights fully shutting off and coming back on. The SRS light does also come on randomly and shuts back off.
What's also odd is that the lights do stop flickering like everything is normal randomly as well.
I have checked to see if fuse 15 is still good which it is, i did also check the o2 sensor harness which did have stripped wires, i did put electrical tape around the exposed wires. Nothing has changed. no CEL's
I do have an OBD Code Reader and while driving it was fluctuating between 14V to 15V.
I have also tightened the Belt and cleaned the ground cables to rule anything out.
So the question is, is the alternator going to crap out soon or am i looking at other issues.
Old Jan 14, 2015 | 05:47 PM
Former User's Avatar
Default Re: Alternator On its Way Out? 00 Civic EX
Replace the alternator.
Old Jan 14, 2015 | 09:27 PM
SequoiaHonda's Avatar
It sounds like the alternator. Time to replace it for sure. I'm not sure if the battery light comes on when there's low voltage issues. I never seen that happen on my 00 ex. Mine has 182k miles on it.
Old Jan 15, 2015 | 09:32 AM
tamboo's Avatar
10 Year Member
if u r broke like me just replace the brush assembly.
2000 HONDA CIVIC Alternator / Generator Brush
Old Jan 15, 2015 | 06:21 PM
mimog3's Avatar
10 Year Member
Thanks everyone. Swapped out the alternator and everything is all good. It's a remanufactered one from advance auto (driveworks). If anyone wanted to know
Old Mar 31, 2015 | 12:35 PM
n87romeo's Avatar
exact same problem; exact same solution
thanks
Old Mar 31, 2015 | 01:00 PM
gking2's Avatar
What did it run you? I just rebuilt mine for 10 bucks tests well now
Old Apr 1, 2015 | 09:48 AM
ThePooh's Avatar
If it starts happening again with the new alternator, I would replace the ELD with another one.
AjHawk
68
Oct 14, 2019 11:29 AM
tianporn
Apr 17, 2012 10:48 PM
brianjec
Sep 27, 2010 05:44 PM
Smarg
Jun 26, 2010 05:30 PM
justinwebb
Mar 9, 2009 11:45 AM
