Need opinion on trans problem
Old Jan 12, 2015 | 10:36 AM
jmh51193's Avatar
Default Need opinion on trans problem
I recently bought a 99 honda accord with "bad trans" After looking at it I found that the output shaft seal was leaking and the trans had no fluid in it. The previous owner said he replaced the trans with a junk yard one but it was no good. Before I installed the trans I bought for it I figured I would replace the seal and fill it up with fluid just to be sure it was bad. I fixed the seal and filled the trans with dextron III fluid ( I know I should use honda but didnt want to waste the money if it was no good). The transmission shift very well in all the forward gears but I cannot get reverse to engage. Also when in neutral it acts like its almost halfway in drive. Any ideas on other things to check before I replace it?
Old Jan 12, 2015 | 11:07 AM
jmh51193's Avatar
Default Re: Need opinion on trans problem
It actually goes forward in every gear but park and has p1738 code
Old Jan 12, 2015 | 04:21 PM
Lost Again's Avatar
1738 is for the second clutch pressure switch....pull it and be sure the port is clean and the inside of the switch.....heck take the one from the JY trans and install it and see what you have from there
mozee82
25
May 19, 2010 05:30 AM
driftam1
Apr 21, 2008 09:35 AM
Probot
Jan 4, 2008 04:22 AM
Probot
Jan 2, 2008 06:26 AM
savagenomore
Jan 30, 2007 03:02 PM
