Honda won't start after sitting a few months
Old Jan 10, 2015 | 09:10 AM
xXViperXx's Avatar
Default Honda won't start after sitting a few months
98 civic ex 5spd. The car cranks but won't start.
The car ran great but I bought another car and didn't drive it through the months of October - December. Once during that time I started it and it started fine.
There is 3/4 tank of gas in the car.
I checked spark by putting a flat head in the spark plug wire and it sparked from the screwdriver to a bolt.
I pulled the spark plugs out after I tried to start it a few times. They smelled a bit like gas. The strange thing was they came out with little to no resistance so I just put them back and tightened them down. I wonder if they loosened because of how cold it's been?
I put a good battery in the car and it still cranks and won't turn over.
The belts rotated when I attempted to start the car.
The fuel pump primes as normal, did not sound different at all.
What do you think the next thing I do is?
Old Jan 10, 2015 | 09:14 AM
1991_crxsi's Avatar
Default Re: Honda won't start after sitting a few months
Change plugs and change dizzy cap and rotor... cross fingers and crank it up.
Old Jan 10, 2015 | 09:46 AM
slomofo's Avatar
GDD Member
This sounds unconventional, but give it a shot.
Remove spark plugs.
Pour a tiny amount of oil into each cylinder, like about as much as a teaspoon's worth.
Put new plugs in.
Get in the car, turn the key to the ON position, but don't start, wait about 5 seconds.
Turn ignition OFF and then ON again for another 5 seconds.
Now crank the engine over.
Does it start? If it does, it'll smoke for about 2 minutes.
Old Jan 10, 2015 | 09:49 AM
xXViperXx's Avatar
Remove spark plugs.
Put new plugs in.
Definitely unconventional but it won't hurt to try. Before I do, could you advise why this route?
Old Jan 10, 2015 | 11:12 AM
xXViperXx's Avatar
Cap and rotor replaced, no start, still cranks. Tried the oil as well in the cylinders and still nothing.
A friend of mine thinks it might be the engine crank sensor, but I don't know much about it or if it fails the car won't start.
Old Jan 10, 2015 | 11:38 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you may have to drain the gas, the **** they call gas today absorbs water like crazy, and the water sinks to the bottom, chances are there is a layer of water that the pump sock is sitting in, it's probably in your filter now too, it's called phase separation, all it takes is a couple of teaspoons of water and the ethanol and water will end up on the bottom of the tank and the remaining fuel floating on top,
Old Jan 10, 2015 | 12:08 PM
NotARaCist's Avatar
I never narc'd on nobody!
Is the CEL on? Does it work? What color is your spark? How much fuel pressure do you have when measured at the filter? Basic crank/no start diagnostics.
Old Jan 10, 2015 | 12:34 PM
90 days is about the maximum limit for corn gas to sit before you have issues
Old Jan 10, 2015 | 01:07 PM
Former User's Avatar
These^
Check for CEL codes and test spark quality using a spare spark plug. Click the Spark link in my signature.
Old Jan 10, 2015 | 01:21 PM
xXViperXx's Avatar
No CEL light and it does work. I haven't yet checked fuel pressure at the filter but will do so. I'll also look at your link, Ron, and see how it goes.
The spark I saw when I used the screwdriver was orange.
I know on an EG there is a plug on the gas tank where I can drain the gas from, but is that also the case with an EK?
Old Jan 10, 2015 | 02:02 PM
grumblemarc's Avatar
The Grumpiest
Orange spark = weak spark.
Old Jan 10, 2015 | 02:53 PM
92ehatch's Avatar
Test the spark by pulling a plug and grounding it to the chassis (laying it on the valve cover works)
Now what color is the spark
Old Jan 12, 2015 | 10:46 AM
slomofo's Avatar
GDD Member
Because your cylinder walls are dry and there isn't enough compression to start which will usually result in gas soaked cylinders that makes it even worse.
Sent from my Nokia 5190 using IB AutoGroup
Old Jan 14, 2015 | 09:31 PM
SequoiaHonda's Avatar
Probably bad gas and may have to replace the fuel filter as well.
EcivicG
20
Aug 11, 2008 06:09 PM
Patman
Feb 6, 2007 11:28 AM
chinese buffet
Jul 16, 2006 05:09 AM
ICeDoUt
Aug 18, 2005 01:38 PM
Peligro
Jun 21, 2003 06:43 PM
