2000 Accord Dome Light and Rear Locks
Old Dec 27, 2014 | 09:25 PM
Mnalley's Avatar
Default 2000 Accord Dome Light and Rear Locks
I own a 2000 Honda Accord Special Edition 4cyl 216k miles. The issues I am having is a Dome light that only works when it wants to. Map lights are working perfectly as are the door lights. When you open the doors (all 4) no dome light. The switch for off, on with door, always on does nothing either. I have checked the terminals for corrosion and also the terminals at the map light. No corrosion. like I said it works when it wants to.
The other issue is the rear door locks do not work with the switch or remote. I have to manually lock the rear doors. When you unlock it,horn beeps,lights flash and only the front 2 unlock. When you lock it, no horn, no lights, and only the front 2 lock. I have 2 remotes and its the same with both.
ANY help will be appreciated.
woj
Feb 13, 2018 06:17 AM
harrisbhj
Aug 25, 2017 05:43 AM
GRIM$
Jul 14, 2014 12:59 PM
yashuvp
Jan 4, 2013 08:23 AM
