B18c5 Ignition rotor????
Old Dec 27, 2014 | 10:36 AM
Smccorkeljr's Avatar
Default B18c5 Ignition rotor????
My 2000 civic ignition rotor button does not have a screw in it.There is no place for a screw.I have turned the engine over to move the rotor multiple times and there is no screw or place for a screw on it.any suggestions on how to get the rotor off to change it?
Old Dec 27, 2014 | 10:37 AM
Former User's Avatar
Default re: B18c5 Ignition rotor????
Remove the entire distributor. Carefully break or cut off the rotor.
The engine is a b18c5 and the distributor says td84
Old Dec 27, 2014 | 10:38 AM
EsotericImage's Avatar
Retired Moderator
sounds like a non oem rotor
Any idea of what rotor to use, if I get it off?
Old Dec 27, 2014 | 10:41 AM
any idea on how to get a non oem rotor off?
Old Dec 27, 2014 | 10:47 AM
Default Re: B18c5 Ignition rotor????
i don't understand what's holding the rotor on.there is no screw.
Old Dec 27, 2014 | 10:53 AM
wunfstgsr's Avatar
Loved
Community Favorite
The rotor edge where it makes contact with the cap needs to point towards the exhaust manifold and the screw will be facing the intake manifold. If it's not there then idk never heard of a rotor not held on by the screw.
Old Dec 27, 2014 | 10:58 AM
wunfstgsr's Avatar
Loved
Community Favorite
Post some pics
Old Dec 28, 2014 | 07:47 AM
Xian's Avatar
I've been told that Honda ditched the screw on rotor in favor of one that's pressed into the shaft. This isn't something I've personally confirmed but it was from someone I trust with Honda stuff...
Old Dec 29, 2014 | 08:24 AM
94eg!'s Avatar
#1 Super Guy
Loved
The Honda rotors always screw on. It sounds like you have an aftermarket distributor. I have a Distributor Kings distributor on my CRX and have the same issue. The rotor has a spring mechanism inside it that locks onto the distributor shaft. Essentially you have to figure out how to release the mechanism or pry the dumb thing off. I've never done this, but I have read about it here:
https://honda-tech.com/tech-misc-15/...izzys-2823435/
Old Jan 8, 2015 | 06:08 PM
wunfstgsr's Avatar
Loved
Community Favorite
My distributor died recently and i got a used one its a Richporter distributor and the rotor was old and worn, it was pressed on like the one above, so i took a flat head and a hamer and from the side i put the screw driver in and lightly tapped the bottom of the rotor and it came off, and the hole for the screw is on the shaft so i just put a new after market rotor and used a spare screw i had in my box and its fine.
97SS
May 12, 2009 10:07 PM
Flux
Aug 18, 2003 12:22 AM
absolutgsr
May 28, 2002 11:53 PM
bocian
Feb 20, 2002 06:50 PM
blackls
Jul 5, 2001 07:31 PM
