How Difficult to Replace Cap and Rotor?
Old Aug 17, 2003 | 08:23 AM
Flux's Avatar
Default How Difficult to Replace Cap and Rotor?
Thinking of doing this myself, but I've never done it before and am not sure of what is involved. How difficult is this DIY job?
Old Aug 17, 2003 | 08:26 AM
vtec.dc2's Avatar
Default Re: How Difficult to Replace Cap and Rotor? (Flux)
its easy to replace cap (unscrew in 4 corners).. the rotor will be right behind it.. inspect the cap first, you might not need to replace it, same for rotor, if its not fried, then you might still use it.. if rotor doesn't align.. just turn the car until it does so you can unscrew it
might require some torque to take of the rotor..
Old Aug 17, 2003 | 09:19 AM
SurferX's Avatar
It's very easy as long as you don't strip the rotor screw. That's the only tricky part is to not strip that screw because it's on there real tight.
Old Aug 17, 2003 | 10:34 AM
py1188's Avatar
Default Re: How Difficult to Replace Cap and Rotor? (SurferX)
Ditto. That screw could be a real PITA if you strip it. Make sure to replace the screw, don't resue the same old one. Worth spending the extar $$ to not have to worry about it stripping
Old Aug 17, 2003 | 11:54 AM
muse's Avatar
Default Re: How Difficult to Replace Cap and Rotor? (py1188)
I just remove the distributor altogether. It's pretty easy, just make sure you scribe the top of the distributor and mounting tab so you don't lose your timing, and take note of how the plug wires go into the cap.
Old Aug 17, 2003 | 11:58 AM
Eva01's Avatar
Default Re: How Difficult to Replace Cap and Rotor? (muse)
Done in 30 minutes easy...as long as you don't strip that screw as it was mentioned earlier.
Old Aug 17, 2003 | 12:38 PM
Utilitarian's Avatar
It's not bad. When you take the cap off the rotor probably won't line up so the screw is exposed (toward the back of the car). Getting the rotor to line up is a pain. Instead of reassembling the cap & all, just unplug the big plug next to the valve cover and bump the engine until the rotor comes around giving access to the screw that you better not strip.
Old Aug 17, 2003 | 12:45 PM
Mr.Integra's Avatar
easy.. just be very careful not to strip the screw.. i stripped mine before so i had to DRILL it out
Old Aug 17, 2003 | 01:12 PM
skafia's Avatar
25 Year Member
Default Re: How Difficult to Replace Cap and Rotor? (Mr.Integra)
It's CAKE.
Old Aug 17, 2003 | 07:21 PM
Bbasso's Avatar
Before you go and do the job, go to a hardware store and pic up an assorted set of phillips head bits ( the ones with the little teeth) and that stubborn screw will come out very easy if you use the right size phillips.
I first tried months ago and when I was t0ld this from a mechanic that had 20+ yrs, I did the job in 15 min.
Old Aug 17, 2003 | 11:45 PM
GZR4DR's Avatar
Default Re: (Bbasso)
Use a good screw driver, less than 5 minute job. BTW pull the damn distributor off, easier that way IMO. White out works good for marking the timing.
Old Aug 18, 2003 | 12:22 AM
NA gs-R 05 C
Guest
Posts: n/a
its an easy task to diy.
218luder
Feb 7, 2008 08:39 PM
hotdoggies
Jan 27, 2006 12:08 AM
Black R
Jul 9, 2005 12:46 PM
machinehead
Oct 21, 2003 04:14 PM
Mike P.
Aug 2, 2001 10:19 PM
