94 Heater not working properly
Old Dec 23, 2014 | 05:32 PM
ls1formula98's Avatar
Default 94 Heater not working properly
So I just bought this 94 accord. The heater doesn't seem to be heating. The blower is working, so I know its not that. I called the guy who I bought it from, he recommended I replace the temp switch/****. This is my first Honda, so sorry If this question is a simple fix. Thanks In Advance.
Old Dec 23, 2014 | 06:04 PM
therhett17's Avatar
Default Re: 94 Heater not working properly
I doubt its the ****, but you can take it off and turn the metal with some pliers as far in the red as it will go, and see if that helps. Also, check your coolant level, not enough coolant flowing through the system can cause little or no heat. Or, it could be a bad thermostat not allowing the engine to heat up properly.
Old Dec 24, 2014 | 04:42 AM
tim73's Avatar
Check your heater valve. Make sure it is opening when you turn the **** to hot. then check both hoses to make sure theyre both hot.
Old Dec 26, 2014 | 09:18 PM
nus_dogg's Avatar
This!
The heater valve is located by the firewall. Just follow the heater hose located underneath the distributor and follow it back. It'll be connected to this black plastic looking valve. Sometime that valve is stuck close causing no coolant to carry in the heat. You just gotta loosen it by closing and opening it a few times, just be gentle cause you can break/crack it.
Old Dec 28, 2014 | 09:29 AM
Originally Posted by nus_dogg
This!
Is this the vaive open/close you speak of? If not what does this control?
Old Dec 28, 2014 | 10:49 AM
belairbrian's Avatar
that is it
Old Dec 28, 2014 | 11:05 AM
Originally Posted by belairbrian
that is it
k, thanks. So is that connected to the heat/cool control ****? Thanks again.
Old Dec 28, 2014 | 03:50 PM
tim73's Avatar
Yeah, you should see it moving, when you turn the ****.
Old Dec 28, 2014 | 03:51 PM
tim73's Avatar
ideally if you have a heat gun, you can see what the temp is on both sides of the valve. When opened, it should be the same. Should be very close also, on the return line.
Old Dec 30, 2014 | 07:52 PM
19Accord97's Avatar
If it isn't the ****, I would go ahead and change the thermostat and do a coolant flush. Hopefully that will take care of the problem. If not, your heater core could be bad/clogged.
2002hondaCivic
Honda Civic (2001 - 2005)
Apr 13, 2018 03:50 AM
LatnKng
Nov 27, 2011 08:15 AM
theorigkav3
Feb 9, 2011 11:49 AM
93BLKXSi
Oct 20, 2005 01:59 PM
Milton90accord
Oct 10, 2003 04:11 AM
