300 whp
Not possible N/A with your current motor! if you want 300 whp N/A look into a k24. if you want to stay with the SOHC a piston/rod turbo set up will get you there.
With Your engine you could gain about 15-30 WHP if you built it up NA for around $2,000 in parts and tuning but to get to 300 WHP which means nearly tripling your current WHP then only Forced Induction can do it on that engine and you would need to drop close to $5500 if you wanted a car that could last more then a week at that power level.
jdmcivic22
Mar 19, 2007 10:38 AM
