ek9 brake swap
Hey guys!
I have a 96 civic hatch and i soon will be doing a rear disc brake swap on it. I'm getting the brakes from a 95 integra in a scrap yard. Basicly what im trying to say is what should I be looking for when I get it and putting it together. This will be my first mod in the car so I'm prity hype about it.
you may need new bushings if u remove it completely piece by piece the more u keep the whole section whole the better off u will be not replacing old bushings and be sure to grab the proportioning valve from the car... I would definitely not put these swaps on my easy list as these cars are rusting more n more
Why does he need a prop valve?
eH.
Umm...did you read what others have posted? V
The best answer I'll give you is research brake swaps and prop valves for yourself and come to your own conclusion.
I chose not to swap prop valves when I did my rear disc conversion. I've got a 92 Civic VX and left the "3030" valve in. The 92-95 Civic Si that comes standard with rear disc has a "3040" prop valve and the Integra comes with the "4040" prop valve. After much reading I decided not to swap. I can tell you that I have taken my car from +60 mph applied brake pressure to where the tires begin to screech (locking up the brakes, as I have no ABS either) and I had ZERO adverse braking conditions.
So read and understand the thoughts on whether a prop valve swap is necessary.
Threads like this Prop Valve Theory. There are even better ones out there, So read, read, read!
Doesn't matter. You're only after the rear trailing arms with the disc spindles. The ABS lines on an Integra run along the rear lower control arms. The only part of the ABS system that you would transfer, inadvertently, would be the ABS ring on the wheel bearing/hub. No biggie since you don't have the sensor to read the ring anyway.
eH.
eH.
imadigitalgod
Sep 2, 2010 10:08 AM
fwlan
Oct 4, 2006 06:32 PM
The DX Rex
May 24, 2005 08:28 AM
