ek9 brake swap
Hey guys!
I have a 96 civic hatch and i soon will be doing a rear disc brake swap on it. I'm getting the brakes from a 95 integra in a scrap yard. Basicly what im trying to say is what should I be looking for when I get it and putting it together. This will be my first mod in the car so I'm prity hype about it. |
Re: ek9 brake swap
Better check for e-brake cable fitment ... check the FAQs/DIYs for what's required.
Re: ek9 brake swap
you may need new bushings if u remove it completely piece by piece the more u keep the whole section whole the better off u will be not replacing old bushings and be sure to grab the proportioning valve from the car... I would definitely not put these swaps on my easy list as these cars are rusting more n more
Re: ek9 brake swap
Originally Posted by apexi_rsx
(Post 50086721)
Why does he need a prop valve? eH. |
Re: ek9 brake swap
I did a lot of reading and all that have done brake swaps don't need to change the prop valve on hatchbacks, and yes the ebrake cable is needed as well.
Re: ek9 brake swap
Integra likely has ABS anyway, so no prop valve.
Re: ek9 brake swap
But does the 95 integra even have ABS? And do I still need a prop valve (40/40 prop valve)? Also my car does not have ABS
Re: ek9 brake swap
Originally Posted by adzenry25
(Post 50089919)
Originally Posted by deschlong
(Post 50086824)
(Post 50089919)
I chose not to swap prop valves when I did my rear disc conversion. I've got a 92 Civic VX and left the "3030" valve in. The 92-95 Civic Si that comes standard with rear disc has a "3040" prop valve and the Integra comes with the "4040" prop valve. After much reading I decided not to swap. I can tell you that I have taken my car from +60 mph applied brake pressure to where the tires begin to screech (locking up the brakes, as I have no ABS either) and I had ZERO adverse braking conditions. So read and understand the thoughts on whether a prop valve swap is necessary. Threads like this Prop Valve Theory. There are even better ones out there, So read, read, read!
(Post 50089919)
eH. |
Re: ek9 brake swap
alright thanks!
