Getting positive on fog light housing (solved)
Old Nov 13, 2014 | 03:59 PM
JEAZY39's Avatar
Default Getting positive on fog light housing (solved)
For some reason i couldn't find out why my fuse for my fog lights kept blowing until i found out that my housing on my fog light is getting positive power. For some reason i don't know why i checked my wiring and it looks good to me the way how it's suppose to be wire but now everytime i put on my bumper the fuse will blow because the fog housing is getting positive feed n the ground is the frame does anyone know why the fog housing is getting positive feed?
Old Nov 13, 2014 | 06:04 PM
92ehatch's Avatar
Default re: Getting positive on fog light housing (solved)
Does it work without the bumper on the car? the reason i ask is because by your description it does. If that's the case then something is shorting out when you install it
The best bet is to check all the wiring at the housing and the bulbs to ensure no cuts or grounding
Old Nov 14, 2014 | 01:47 AM
tony_2018's Avatar
Fish Twig
Any pics of the inside of the housing?
Old Nov 14, 2014 | 02:55 AM
JEAZY39's Avatar
It works perfectly fine on with the bumper not on but if i take the bumper off and take a test light the test light will light up on the housing of the fogs
Old Nov 14, 2014 | 02:57 AM
JEAZY39's Avatar
I could take some pictures today
Old Nov 14, 2014 | 03:08 AM
92ehatch's Avatar
Kind of sounds like your positive and ground are reversed. when you instal the bumper its grounding to the chassis
Are these Ebay fog lights? They may have pinned the connectors backwards.
Old Nov 14, 2014 | 07:49 AM
tony_2018's Avatar
Fish Twig
Hooking your bumper up does nothing to add power to ground, its not metal. Plugging in the foglight house during the process of re-installing the bumper may cause a circuit short because of poor wiring. You need to check your wiring and check the insdie of the foglight housing.
Old Nov 14, 2014 | 08:48 AM
JEAZY39's Avatar
No i didnt get them off ebay but thats wat i was thinking that they pinned the wire wrong, or put the power wire with ground or something i think im going to take he harrnest appart
Old Nov 14, 2014 | 08:51 AM
Former User's Avatar
Sounds like an internal short to ground in the housing.
Old Nov 15, 2014 | 07:36 PM
JEAZY39's Avatar
Problem solved
The connecter for the fogs positive n ground was too close to eachother and i guess it will either touch or something n it will power the negaive some how so everytime i put the bumper on the ground was being power n blow the fuse ( fog frame was the ground
kaluwa3
24
Mar 3, 2009 07:38 PM
da_rimrocka
11
Apr 26, 2006 01:41 PM
egcivic611
Jan 15, 2006 12:49 PM
Dc2 Powered
Feb 13, 2005 12:46 AM
spankey167
Jan 20, 2004 01:05 AM
