1997 CR-V Dies While Driving
HT White Ops
I've got a 97 CR-V LX Auto with ~120K. I've been having an issue for a while with it dying while driving. It is worse in the cold, and seems to only happen the first drive of the day -- usually within a mile from my starting point. When it dies, I have to let it set for 3-5 minutes and open/close the gas cap.
I have replaced the following:
* Ignition Switch (Recall)
* Spark Plugs
* Plug Wires
* Distributor Cap
* Distributor Rotor
* Ignition Control Module
* Thermostat
* Cleaned IACV
* Did Idle Relearn
* Fuel Filter
* Air Filter
* Recent Oil Change
* PCV Valve
* Brand-New OEM Gas Cap
On My To-Do List:
* Transmission Fluid Change
* Differential Service
* Accessory Belts
* Check catalytic for clogs
Based on everything I've read, my next step is replacing the fuel pump & strainer. Is there anything I should try first before making the jump to the fuel pump?
Thanks!
* Spark Plugs
* Plug Wires
* Distributor Cap
* Distributor Rotor
* Thermostat
* Cleaned IACV
* Did Idle Relearn
* Fuel Filter
* Air Filter
* Recent Oil Change
* PCV Valve
On My To-Do List:
* Accessory Belts
Thanks!
When it doesn't start does it get spark? If so what color? On all 4 plugs? Does it get fuel? What's the fuel pressure? Does the check engine light come on like normal when it doesn't crank for 2 seconds and cut off? Have you had a check engine light?
HT White Ops
CEL behaves as normal, and I have gotten CELs before.
I have had the same issue.. driving down the road and jus shuts off..
Replace ignition harness (dealer recall), replace the ignitor (icm) today. . So far nothing happen.. I had couple spear dizzy at home so I decided to replace it..
Eran if u happen to pen point the issue plz up date
Eran just an update on my side
I recently replace the ignitor with a spear one laying around this past Sunday. ..
And drove my v around alot lately and havent had any issues..
Connorjaymes
10
May 12, 2018 07:28 PM
NOTUNINGNONADA
10
Nov 21, 2017 04:11 AM
sethmoman
Jan 11, 2012 08:44 AM
