97 Civic Rear Drum To Disc Swap
Old Nov 9, 2014 | 03:39 PM
Thor294's Avatar
Icon2 97 Civic Rear Drum To Disc Swap
1997 Honda Civic EX
B18C Swap
LS 5 Speed
Grocery list of suspension stuff. especially a busted lca bolt
By the way
I tried to do this swap on friday...
The passenger side lower control arm bolt that goes to the trailing arm snapped. Apparently you cant BUY THE BUSHING... I need a WHOLE FREAKING LOWER CONTROL ARM!!!!!
I am beyond pissed. Car is grounded now because of that.
god damnit.
Should have went with the brackets lol.
Originally Posted by eHMxhACk
Calm down. Even if what you are saying is true, it isn't, there are other options. Hardrace to start, but it does look like you can buy just the bushing for a 1997 Honda Civic Ex. It's like $13 at Hondapartscheap.com. I'd buy two and replace the other side as well.
eH.
I called 2 Honda Dealers and they said they can only get the bushing for the strut, not the others.
no part # on the highlighted bushing.
Old Nov 9, 2014 | 03:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 92-95 rear drum to disk trailing arm question(s).
Old Nov 9, 2014 | 05:06 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Originally Posted by Thor294
By the way
god damnit.
eH.
Old Nov 9, 2014 | 05:10 PM
Thor294's Avatar
moved this post to main post
Old Nov 9, 2014 | 05:14 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
So try online. I provided you a website that currently shows the bushing available. You can also buy aftermarket Hardrace bushings or go to a junkyard and pull the LCAs from another car. Like I said, options.
eH.
Old Nov 9, 2014 | 05:38 PM
Thor294's Avatar
eH.
see my response. thats from hondapartscheap .
I didn't realize 92-95 had a different rear arm than my 97. I guess this warning doesn't apply to this thread then lol
Old Nov 9, 2014 | 06:49 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
I misread your post about which bushing it was. Anyway, for $56+shipping you can replace all 6 rear LCA bushings with Hardrace bushings.
Or you can still try a junkyard for another 96-00(?) rear LCAs.
eH.
Old Nov 9, 2014 | 07:06 PM
Thor294's Avatar
eH.
That be them.
Im surprised Honduh doesn't have them. Car is at my uncle's garage... so we need parts like yesterday haha.
Old Nov 9, 2014 | 07:11 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Pic is too small. never mind.
Yeah the 96-00 has a different LCA and doesn't have stock bushings separate of the arm. Interesting.
Also, you can always drill the bolt out of the bushing, it will require titanium bits or you will go through at least 3 titanium plated bits to get through the bolt.
I'd say hit up the junk yards and pull one used.
Old Nov 9, 2014 | 07:14 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
TomCat39, your thread was kinda hijacked. Can you just split the threads?
eH.
Old Nov 9, 2014 | 07:58 PM
Thor294's Avatar
You can delete if you'd like haha. I sawzalled the bolt so kinda fubatrd the bushing. New arm coming tomorrow. sigh lol. Lesson learnt!!!!
Old Nov 9, 2014 | 08:44 PM
98civdx's Avatar
Master Detailer
if you can't get the bushing local, just head down to Autozone and have them order the Energy suspension rear lower control arm bushing kit.
SHould be about ~$40-50, but they should be able to get it in less than a day.
Old Nov 9, 2014 | 10:03 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 97 Civic Rear Drum To Disc Swap
Thor please edit the first post to include your complete car information, year, make, model, trim and any modifications.
Hijack now moved into it's own thread.
Thanks.
Old Nov 10, 2014 | 02:10 AM
94EG8's Avatar
Seagull Management
I've drilled the bolts out of those bushings before after remove the LCA from the vehicle.
Also, you can try one for a '92 - '95 Civic and see if it fits. I know they do fit first gen CR-V lower control arms which also don't have the bushings listed separately.
Old Nov 10, 2014 | 03:37 AM
Thor294's Avatar
I noticed I can order it aftermarket. Unfortunately, when I do work at my uncles garage, I need parts that day lol. So its usually OEM stuff... If I want aftermarket, I bring it myself Just want this to be a lesson to peeps that do this.... or just get Scarebird's brackets in the rear
Old Nov 10, 2014 | 05:28 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Glad to see you have your own thread now!!
So did you just order a new OEM arm then?
eH.
Old Nov 10, 2014 | 06:31 AM
tony_2018's Avatar
Fish Twig
1. Drill bolt out, re-tap, beer.
2. cut nut off the back, knock out old bolt, use new nut with new bolt, beer.
Old Nov 10, 2014 | 01:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If the 96-00 is anything like the the 92-95, that bolt doesn't have a nut per say as much as they just tapped a cylinder part of the trailing arm.
It might be a big cylinder piece of metal welded to the trailing arm then tapped. Not really sure, it's coated with some sort of tar/rubber like undercoat material.
I fuxored that up a bit when I drilled mine out so I just used a new nut after it like a locking nut when I did mine. I did that for all three bolts I had to drill out.... that weekend sucked.
And the nut thread size isn't a common size. I was lucky enough I already had picked up ten nuts with that rare thread pitch for my exhaust awhile back. Was fun locating a fastener company who made them.
Old Nov 10, 2014 | 05:27 PM
Thor294's Avatar
Correct no nut. I got a new arm. Alignment tomorrow.... Sigh lol
relentlesstech
30
Mar 4, 2014 03:09 PM
TOP91
Aug 21, 2011 05:15 PM
jlucas
13
Jul 9, 2005 09:01 PM
s73
Aug 26, 2002 04:18 PM
